Regardless of the modem I use I keep getting a "No dialtone detected" error when the Pager Object goes to dial out a numeric message. I have switched modems with a couple of other modems and get the same result. I have two modems installed and use the other for PCAnywhere access. Could they be conflicting with each other? I have already tested the modems with the Windows dialer, they both check out ok.
