Lookout
Lookout 6.6 server/client process not working across network
I have a server and client process setup in Lookout 6.6 using a symbolic link in the client process for all of my data members, switches, etc.  If I have the client process running on the same PC as the server process, everything works fine.  When I open the client process in a client version of Lookout 6.6 on a remote computer, none of my links work.  Everything has a red "X" over it.  Both PC's showing on my network.  What am I missing?
(3,294 Views)
This just a guess, but the symbolic links may be referencing the local computer i.e. \\.\Process\Object.DataMember.  If this is the case change \\.\ to \\ComputerName\ and your remote client should then work as expected.
(3,232 Views)
I already the symbolic link set up with the computer name.  I was able to get it working today.  It was Windows firewall blocking the program.
(3,219 Views)
