09-28-2016 07:37 AM
We have lookout setup to monitor all of our plating tanks. All this data from the tanks get recorded in lookout and then somehow exported to Excel. All the tanks have a document in excel call “tankxx”. The xx will be the number of the tank (ex: tank32). We have all tanks monitored but for some reason tank 63 is not. I need to know how we can setup tank 63 to be monitored and record data like the other tanks. You can call me if needed for a better explanation. This is pretty critical to get fixed so any help would be great
Thank you,
11-04-2016 01:41 PM
For My customers I use the spreadsheet object.
This can be found under Logging when you create a new object.
If you want it with in the same excel file you will need to find the spreadsheet and add a field.
