I am running Lookout 4.5.1. It had stopped logging data and the trends are empty. I was getting Citadel Logging buffer is full for the individual objects. I had shutdown Lookout and logged into the PC as administrator to look at the MSConfig file to verified that Citadel is set to start up. Then I stared Lookout. The process started and is reading data fine. There are no more Citadel logging buffer full alarms, but there is still no logging going on. I even cleaned out the database file where the data is saved. The lighthouse in the task bar says that Citadel is running. I have tried stopping and restarting it with no success.
