Lookout
Info about running ActiveX or dll on Lookout
Hello, I´m working on a gas company and they are interested in acquiring a third party software to use together with Lookout 6.0.2.
This software is used to calculate some values, which are obtained through a modbus in Lookout. The calculated values must be shown in the Lookout client process running.
The third party software designers said that the can compile it as a standalone aplication, a dll or as an ActiveX. I really don´t know much about dll and ActiveX, so my questions are:
1.- Is it possible in Lookout to run a third party dll or ActiveX that interacts with Lookout datamembers?
2.- Should this dll or ActiveX be compiled in some particular way in order to be recognized by Lookout?
3.- Is there some kind of tutorial or process example regarding this issues?
Thank you in advance for your time.
Luciano Di Sarno,
Electronic Engineer.
(5,099 Views)
Lookout can use ActiveX controls.  Simple object based usage.
Lookout cannot use ActiveX methods.  Only properties and functions.
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
(5,088 Views)
Thanks for your answer. Could you please explain me what´s the difference between ActiveX controls and methods?
And if it´s not too much to ask, how to implement this simple object based usage. What are the properties and functions that will run on Lookout?
As you can see, I have a complete lack of information about this, so any help would be really appreciated.
(5,082 Views)
Methods are used for programming ActiveX controls.
Properties are a simple in/out.  Methods are a function call
Example Property:
Object.Property=MyValue
or
MyValue=object.property
Example Method:
MyValue=Object.Method(Parameter)
Lookout doesnt support the method... method.
Good luck
Mike
(5,080 Views)
I see. Thanks for the reply, it really helped. I´ll talk to the software designer and see if it is compatible with the Lookout "methods".
Have a nice weekend!
Luciano.
(5,078 Views)
