08-01-2005 03:05 PM
08-02-2005 01:46 PM
Hi Kevin,
I am assuming the Lookout you want to send the email from is not on a network. You could easily use the Mailer object if you were on a network, and had access to the SMTP server. If dial-up is the only connection to the rest of the world, you can try connecting to the network using Remote Access Service (RAS). Here's some info' on RAS:
I had tried this way back when VPN wasn't as common. I will try to dig up the details and let you know if I find them. I really doubt if I still have them around though
Hope this at least gives you some ideas.
-Khalid
08-03-2005 05:33 AM
08-03-2005 11:16 AM
08-03-2005 02:35 PM
Hi Kevin,
What do _you_ have to do to disconnect? Do you have to click on some tray icon and select "disconnect"? Can this step be automated somehow? For example with a batch file? If yes, then we can have Lookout launch IE (thus connecting to the network), send the email using the Mialer, and then run the batch file to disconnect.
Hope I understood the issue correctly.
-Khalid
