Lookout
How can I connect my Excel file located at the same computer to my Lookout process using DDETable.
I'm currently using Lookout ver.5 in my Win98se.Attached here is the sample of my xls file.
(2,121 Views)
The on-line help file does a pretty good job of explaining the steps. Take a look at "DdeTable on Same Computer" and see if that helps.
(2,121 Views)
Also, check the document found on the following URL:
http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/dab25cf02ef0029c862568ab00677333?OpenDocument
This is a Knowledgebase that gives you a hint on how to retreive a range of cells in Excell using the DDETable.
The "DDETable on same computer" example is located under the >lookout objects>Networking>DDETable chapter on the Lookout On-line help.
(2,121 Views)
