If you input the same value, Lookout will not update it to the server.
I cannot find a good way to force it to write again, since Lookout doesn't think of a same value as an event. To input the same value is just like doing nothing. What you can do is to turn the pot or switch to last value and operate again. Does this work?
Ryan Shi
