Could you clarify if the data you want to extract is physically available in Citadel or not. You can use MAX (Measurement@Automation Explorer) and Historoical Data Viewer to check this. If it is physically available, then you can export data to a tab delimeter text file that you can open in Excel. This feature is available in MAX. I hope this helps.
Best Regards,
Remzi A.
Applications Engineering
