Lookout
Does Lookout Support the OMRON CJ1M PLC via RS-232
Does Lookout Support the OMRON CJ1M PLC via RS-232 ?
(3,200 Views)
Lookout supports the following OMRON PLCS using the
Host Link Serial Protocol:
C20, C200, C500, C1000, C2000, CQM, CPM1.
If the OMRON PLC that you want to use uses the same registers and protocols than the ones above, it should work, but officially, it is not supported.
Something else that you can try is to use the OMRON OPC Server and use Lookout as an OPC Client. Lookout has an OPC Client Object that handles OPC 1.0 Protocol.
I hope this helps
VG
(3,200 Views)
Hello !
This PLC (omron CJ1M) not uses the same register and protocols, and the Omron OPC Server has a price of 1500 $. this is lot of money, will it be developet drivers fore the new model (Omron CS1 and CJ1) ?
(3,200 Views)
