Hello Robert,
For the driver object you are using, there should be an OffHook datamember.
Making this datamember true will keep the connection and not drop the line
after each poll. You may connect a Switch to it and turn it On or just connect
a "true" permanently.
Khalid
"Robert Phillips" wrote:
Lookout makes dialup connection but after first poll, drops line. Am able
to make good connection with terminal program without dropping connection.
