Lookout
Data Table Logging Errors
I have PLC values that are always integer values, yet Citadel is logging (through Data Table object) values of 299.999 or 300.001 instead of 300.  I assume this could be corrected by adjusting logging resolution to 1 instead of .001, but I thought you folks at NI might want to know this to fix it in the next revision.
Ed
(5,432 Views)
Thank you. I can reproduce this problem. I don't think it's the datatable's problem, but Citadel's.
I think it's because Citadel records the double value, but double may be inaccurate. We will look into it.
Ryan Shi
(5,411 Views)
