I'm currently using MAX version 3.0.0.3003 with Lookout version 5.1. I've created some views with MAX and I was wondering if there were some command-line switches that I could use to make MAX go directly to a named view that I have created. Any help would be greatly appreciated. I've tried browsing through the knowledgebase with no success. Regards, Derek
There's a similar discussion in the following thread that describes how to launch MAX and/or activate an open version of MAX. <>
The best way to set views of data logged to the historical database is to use the HyperTrend object in Lookout. You could conceivably have several panels that could easily be viewed with a click of a pushbutton in Lookout to show different HyperTrend views. The HyperTrend can be configured to show the data you need.
If you have any further questions, please post a reply.
Kristi H Applications Engineer National Instruments >
