Lookout
Clients losing connection to server
Please follow below steps to add a configuration file to client machine and see if it helps.
The file logos.ini location:
XP - C:\Documents and Settings\All Users\Application Data\National Instruments\Logos
Win7 or Vista - C:\ProgramData\National Instruments\Logos
If you don't find logos.ini, just create a new file.
Add below information to the logos.ini
[logos]
Global.DisableLogosXT=True
[LogosSockets]
ProcManTimeoutSeconds=xxx
CtrlEnvTimeoutSeconds=xxx
ClassAdsTimeoutSeconds=xxx
where xxx is an integer value. Default value is 5, you can set to bigger number, such as 10.
Message 11 of 13
(1,324 Views)
Sorry to bring this back up from the dead. I am now having the same issue but worse now. Everyday the server drops the client connection at random times. There is no errors or anything that pops up. only way to establish connections is to close the lookout software and restart. IT ran wireshark and the program showed that the IP connections of the clients are still connected. I am running a total of 6258 total I/O points.
Message 12 of 13
(1,094 Views)
Update.
Seems we have finally figured out how to remedy the situation. The problem was with the firewall even when it was turned off. Had to allow these programs through the exceptions list and that seemed to stop the connection issues.
  • Lkads.exe
  • Nicitdl5.exe
  • Lktsrv.exe
  • Nidmsrv.exe
Message 13 of 13
(1,030 Views)
