03-26-2004 09:08 AM
04-07-2004 09:00 AM
04-08-2004 04:34 PM
10-06-2011 01:01 PM
Where can I find the steps to do a Manual Backup of the Lookout Database?
Thanks.
10-10-2011 05:41 AM
10-10-2011 08:05 AM
This backup procedure seems understandable enough.
Now in the event of a citadel database loss or corruption, how is this archive reliably restored. Does Lookout need to be running/stopped? Does the Lookout Database directory need to be cleared/deleted? Can max remember or find the citadel DB archive name or is only the directory location important? Can or how can databases be merged for partial restoration?
Is there a knowledgebase article that explains this? Simplicity is welcome.
10-11-2011 12:53 PM
When it creates the new Database, Lookout doesn't use that Database does it? It's just a backup copy?
10-11-2011 08:28 PM
It's just a backup copy. Actually it's just another database attached.
In MAX, you see all the attached databases under "My Computer". Lookout or other NI product can use these attached databases. If you right click on the database and select detach, Lookout cannot use it. If a database is detached(not delete), the data files are still on the disk, but you cannot see this database in MAX. You can attach it back anytime you need it. If a database is deleted, the data files are deleted.
In Lookout, select Option->System, here is the configuration of the default database it uses. You can also configure a different database for process. In Edit Mode, select File->Modify Process. One process either uses the default database, or a specific one.
10-11-2011 08:31 PM
The archived database is just another database. If you want to recover the data, just archive the data from the backup database to the one you use.
Of course, if the original database is corrupted, you can create a new one for lookout use, and archive data to the new one.
If you detach the database from MAX, you can copy the database folder to anywhere else. When you need it, just attach the database folder again.
