Reply
Highlighted
uninstall NI-VISA in Linux
Does anyone know how to uninstall NI-VISA in Linux? I can't seem to find any documentation describing how this should be done.
Thanks.
(3,221 Views)
Re: uninstall NI-VISA in Linux
I am looking for the same thing (documentation).  When I tried it hung in Pre Uninstallation  ( I had to hit ^C to break out of it).
NI-VISA for Linux
version 17.0.0f1 for Linux
rpm found
dpkg Not found in current path
dpkg not available, uninstall will not be using dpkg.
NI-VISA for Linux version 17.0.0f1
is about to be uninstalled using rpm at /usr/local/natinst
Continue? [Yn] Y
Uninstalling NI-VISA for Linux version 17.0.0f1...
cat: /etc/natinst/linux/linux.dir: No such file or directory
Pre Uninstallation .........................................................................
^C
warning: %postun(niiotracei-17.0.0-f0.x86_64) scriptlet failed, signal 2
Brad Whaley
LabVIEW Certified Engineer
(2,256 Views)
do you have rpm installed on your system ?
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(1,896 Views)
Reply
