01-19-2018 06:24 AM - edited 01-22-2018 02:13 AM
Hello all,
i'm new to the user group and not an expert of Labview. I'm trying hard (for two days now) to install Labview on a gentoo multilib distro. I've removed and reinstalled all the stuff for several times now and I'm running out of new ideas of howto install labview. It should run together with a PCI 6229 - Card.
I've started with NI-VISA 17.0.0 for Linux.
The installationprocess did finish. I've updated the kernelmodules, and they are all loaded.
Here is lsmod:
Module Size Used by nipxifpk 53978 0 nipxigpk 13306 0 nipxirmk 278376 2 nipxifpk,nipxigpk nimxdfk 419927 2 nipxifpk,nipxigpk nimdbgk 300916 4 nipxifpk,nipxigpk,nipxirmk,nimxdfk NiViPciK 70373 0 NiViPxiK 17909 0 nidimk 310569 2 nipxirmk,NiViPxiK niorbk 64537 6 nipxifpk,nipxigpk,nipxirmk,nimdbgk,nimxdfk,nidimk nipalk 909346 9 nipxifpk,nipxigpk,nipxirmk,NiViPciK,NiViPxiK,nimdbgk,nimxdfk,nidimk,niorbk nikal 65240 9 nipxifpk,nipxigpk,nipxirmk,NiViPxiK,nimdbgk,nimxdfk,nidimk,nipalk,niorbk
1) Problem
Running visaconf I get the following error message:
Can't load library /usr/local/lib/liblvrt.so.15.0 /usr/local/lib/liblvrt.so.15.0: wrong ELF class: ELFCLASS64 To download the LabVIEW Runtime engine, go to http://www.ni.com/rteFinder?dest=lvrte&version=15.0&platform=Linux&lang=en
Well, it tells me to install LabVIEW2015RTE_Linux.tgz. I did this in my first installation cycle, but the error stays the same.
Any hints on this ?
Please have a look at the spoiler, there is an update:
2) Problem
Running lsni64 gives:
Scanning localhost for devices... libnipalu.so failed to initialize Perhaps you need to run updateNIDrivers Aborted
I've found a 32bit version an 64bit version:
/usr/lib64/i386-linux-gnu/libnipalu.so /usr/lib64/i386-linux-gnu/libnipalu.so.1 /usr/lib64/i386-linux-gnu/libnipalu.so.17.0.0 /usr/lib64/x86_64-linux-gnu/libnipalu.so /usr/lib64/x86_64-linux-gnu/libnipalu.so.1 /usr/lib64/x86_64-linux-gnu/libnipalu.so.17.0.0 /usr/local/natinst/nipal/lib/libnipalu.so.17.0.0 /usr/local/natinst/nipal/lib64/libnipalu.so.17.0.0
Please have a look at the spoiler, there is an update.
Again, any hints on this ?
I did no go any further with the installation during my actual cycle of the installation procedure cause I can say this will not change if I will install Labview 2015, nidaqmxbase-15.0.0 and LabVIEW2015RTE engine, as I did in the installation cycle before.
I hope, you can give me any hints 😉
Have fun,
kaffeesurrogat
01-19-2018 10:46 AM
Hello, any chance to use CENTOS 7.4?
For me this is the best linux with labview.
Please let me know.
01-22-2018 02:07 AM
Hey vphino13,
this might happen one day, right now I don't want to give up 😉
Cheers,
Kaffeesurrogat
01-22-2018 02:14 AM
Hello All,
i've added the solutions to the spoilers in the first message 😉
Have fun,
kaffeesurrogat
