04-05-2019 04:01 PM
I configured my hardware, cDAQ-9185 + NI 9232 on a windows machine with MAX and nidaqmx v.18.0. Everything went well there. Then I exported the hardware configuration as a configData.ini file in order to import it later on my CentOS 7 machine. It has the latest ni-daqmx rpm packages installed and the driver were linked to the kernel with
dkms autoinstall
I tried to apply the hardware configuration with the following command:
[user@host]$ nidaqmxconfig --import configData.ini --replace Processed: Failed Error -201057 Hardware product type specified is invalid. Enter a valid product type. If the product number you entered is an actual product type, ensure the product type is appropriate for the object you are configuring. For example, do not use the product type of a PXI device where an SCXI module is expected. Product Type: cDAQ-9185
And here is the content of the configData.ini file:
$ cat configData.ini [DAQmx] MajorVersion = 18 MinorVersion = 0 [DAQmxCDAQChassis cDAQ9185-1] ProductType = cDAQ-9185 DevSerialNum = 0x1CF6CD4 BusType = TCP/IP TCPIP.Hostname = cDAQ9185-1 TCPIP.EthernetIP = 169.254.153.205 TCPIP.EthernetMAC = 00:80:2F:18:7A:DF TCPIP.EthernetMDNSServiceInstance = NI cDAQ-9185 01CF6CD4 TCPIP.DevIsReserved = 0 [DAQmxCDAQModule NI9232-2] ProductType = NI 9232 (BNC) DevSerialNum = 0x1D5A0B7 CompactDAQ.ChassisDevName = cDAQ9185-1 CompactDAQ.SlotNum = 1
Any ideas?
04-08-2019 02:30 PM
OK, I digged a little bit deeper. After getting the cDAQ-9185 chassis IP address I tried to configure it directly using the python-nidaqmx library.
Here is my python file:
from nidaqmx.system.device import Device d = Device.add_network_device('10.254.254.201', attempt_reservation=True)
And when launched, here is the result:
DaqError: Device cannot be created in MAX because a driver could not be found for the device. You may need to upgrade NI-DAQmx.
Is the cDAQ-9185 really supported by NI-DAQmx 18.1 in Linux? It is on Windows. If this is the case, that is quite disappointing ...
04-08-2019 02:43 PM
Another (related) question: is there somewhere an accurate list of what hardware is supported on Linux exactly?
Thanks.
04-08-2019 02:53 PM
I don't know of a consolidated list, but each of the driver READMEs generally lists the hardware supported by that driver on Linux.
04-08-2019 03:42 PM
Thanks @GabeJ, I already saw that Readme. But for the NI DAQmx readme, only PCI and PXI cards are listed, not a single cDAQ card and/or chassis is. Does this mean that no cDAQ are supported on Linux?
04-08-2019 03:51 PM
Yes, that's the conclusion I would draw.
