Reply
Solved! Go to solution
libnipalu.so failed to initialize error for all NI related commands
Dear friends,
Already, I’ve installed two DAQ cards on PCI slots of a computer with a Centos 6.9 32-bit operating systems with the kernel version 2.6.32-754.2.1.el6.i686. The first one is PCI-6225 and the second is PCI-6509. I’ve followed all the steps of the instruction to update the Kernel and install the DAQmx802f0.iso driver successfully. However, now when I try to execute a command to verify the installation I just receive some errors. In more detail, I’ll elaborate on this issue as follows:
[user@localhost ~]$ nilsdev
Perhaps you need to run updateNIDrivers
Aborted
Unfortunately, I've run updateNIDrivers and it has been executed successfully, the problem isn't solved though.
Here are some outputs of NI routine commands:
[user@localhost ~]$ lsmod | grep ni
nikal                  55889  0
[user@localhost ~]$ /etc/init.d/nipal start
/etc/init.d/nipal: line 81: /tmp/nipalk-load.log: Permission denied
FATAL: Error inserting nipalk (/lib/modules/2.6.32-754.2.1.el6.i686/kernel/natinst/nipal/nipalk.ko): Kernel does not have module support
error: nipalk failed to load
possible causes:
   nipalk was not versioned for this kernel (2.6.32-754.2.1.el6.i686)
   modules are not enabled for this kernel (CONFIG_MODULES)
   unresolved symbols
possible solution:
   if you recently installed a new kernel or have rebooted to
   a different kernel from one you were previously running then run
   /usr/local/bin/updateNIDrivers
   to version your NI drivers for kernel 2.6.32-754.2.1.el6.i686
Please help me to resolve this problem.
(978 Views)
Accepted by topic author soheil08
08-05-2018 03:33 AM
Re: libnipalu.so failed to initialize error for all NI related commands
NI recently released its July 2018 drivers for Linux.  I'd recommended uninstalling your current NI software and installing ni-daqmx version 18.1 instead.
(964 Views)
I can confirm this solved a similar issue for me soheil08
________/~~~~~~~~*********~~~~~~~~\________
Certified delinquent LabVIEW developer. Recertifying at next NI Days
(960 Views)
Highlighted
Thanks, I Installed NI-DAQmx 8.0.2 - RedHat, SUSE and NI-DAQmx Base 3.5 - RedHat, Scientific Linux, SUSE. You mean I should uninstall both of them and just install the new Linux driver version 18.1 using Linux Repos.?
(947 Views)
NI's July 2018 release of drivers should support both the 6221 and the 6509. Unless you had a pressing need for DAQmx Base 3.5, I'd recommend uninstalling both and installing NI DAQmx from the July 2018 release.
(924 Views)
I tried to solve this problem installing the drivers update but I don´t solve the issue.
We installed NI-VISA 15.0 on CENTOS7 with labview 201732 bit. When running our application, the following error message appeared and the program aborted.
Do VISA 16, 17 or drivers 2018 support centos7 32 bit?
Could be possible to use LabVIEW 2017 with visa 15 without problems?
thanks in advance
(134 Views)
Reply
