09-14-2009 12:44 PM
Hi all
I need to install a gpib card on a linux machine to program an old tektronix HFS machine using a c program.
I have been following all the related posts with regard to the installation procedure. I dont have much experience with intsalling stuff on linux however I think all the how tos have taught me a lot.
ok I downloded the ni488225L.iso and extracted it.
the kernel version is 2.6.28-15-generic (uname-r)
and gcc version 4.3.3
after linking bash to sh
i ran the installer script
sudo sh INTALL --nodeps
and I get the error
* Kernel source in /lib/modules/2.6.28-15-generic/build does not appear to be
* for the 2.6.28-15-generic kernel.
* Ensure that kernel source for the 2.6.28-15-generic kernel is installed
* and configured. Refer to the README file for the product you are *
* installing for information about configuring your kernel source. *
******************************** ERROR ****************************************
however when I checked through the synaptic I have the correct linux header installed for this version of the kernel
output of
ls -d /lib/modules/$(uname -r)/build
then I tried installing each of the rpms indivisually by
following
http://forrestbao.blogspot.com/2006/10/labview-7-installation-error-solutions.ht ml
and i got the folder under /usr/local/natinst ls -la
drwxrwxr-x 10 root root 4096 2009-09-13 19:58 ni4882
drwxrwxr-x 5 root root 4096 2009-09-13 19:10 nikal
drwxrwxr-x 7 root root 4096 2009-09-13 19:11 nipal
drwxrwxr-x 7 root root 4096 2009-09-13 20:00 nispy
drwxr-xr-x 7 root root 4096 2009-09-13 20:12 share
no the problem is if i do modprobe nikal I get
even if i do /src./configure i get
Can you please suggest as to what should I do to solve this problem and finally install the GPIB card
output of lspci | grep GPIB
01:09.0 Communication controller: National Instruments PCI-GPIB (rev 02)
so the device is detecte
09-15-2009 08:59 AM
Hi
Plese follow these steps:
With alien we will change *.rpm to *.deb. With dkpg command we will install the deb package.
# alien nikali-1.10.0-f0.noarch.rpm
# dpkg -i nikali_1.10.0-f0_all.deb
If there is something different in this tutorial from my previous one it is the fact that, some packages are going to create a scripts named *InstallerUtility.sh. where * is the name of package installed. We must find and execute these scripts after each dpkg.
# cd /usr/local/natinst/nikal/bin
# ./nikaliInstallerUtility.sh
# ./installerUtility.sh
# ./updateNIDrivers
Reboot? yes
After it, check it that module nikal is working:
# modprobe nikal
NI488.2 INSTALLATION
The next step is to install NI488.2, first download NI-488.2-beta-2.5 and follow the same steps that we follow with nikal, remember unpackage NI-488.2-beta-2.5.1b1.tar.gz.
# cd /home/vicente/Escritorio/NI4882/NI-488.2-beta-2.5.1b1
# ./INSTALL --nodeps
After to install using the method ./INSTALL --nodeps it appears errors post installation. At this moment if you check it nikal you will find that nikal isn't working. Don't worry follow these steps:
# cd /home/vicente/Escritorio/nikal/tmp/nikal-1.10.0f0/rpms
# dpkg -P nikali
# ./updateNIDrivers
Reboot? yes
Right after it, you can check it that you have installed nikal, nipalk, gpibrtk and a new demon nipal.
# modprobe nikal
# modprobe nipalk
# modprobe gpibprtk
# /etc/init.d/nipal restart (appears a error but nipal is working)
I know that it is a pretty peculiar method (even for a human beings) but works. For example if you have a PCI/GPIB card you can test it writting up this
# gpibtsw
What happens after gpibtsw?
09-15-2009 10:21 AM
hey thanks Vicente Muñoz:
ok I was finally installed nikal 1.10, I realized that earlier I was trying to install NIkal 1.8 and 1.9 but neithe rof them worked. the nikal modul also got loaded correctly.
however now I have a different problem.
when I try to install ni488.2 and run the ./INSTALL--nodeps
it lists the entire package lists and says that they are already installed, however I deleted the package folders for nipal etc from /local/user/natinst and /etc/natinst.. now the problem is that I cant install these packages from the install script because it thinks that those packges are installed however they are not since I deleted them.
09-15-2009 11:05 AM
Hi tanuj22
Please forget it the script install, The people who made it, were not thinking about Ubuntu Distro at that very moment.
The script is for Suse, Red Hat and Mandriva, and I'm not going to talking about the reason of this because I'm very tired of discussing about the topic
and I know that people of NI (Bohrer,NeilS,etc) too.
Please follow my last tutorial till installation of NI488.2 (Don't follow Visa Installation, there is a error that I'm trying to solve).
Good luck
09-15-2009 11:14 AM
hey that is what I did but even you are using the install script to install ni4888.2 right, I was able to install nikal. but now when i do
lsmod | grep ni
69576 0
sudo modprobe nipalk
FATAL: Module nipalk not found.
09-15-2009 11:30 AM
Ok,
did you install these packages before?
# apt-get install linux-headers-2.6.24-24-generic
# apt-get install alien
Remenber that your kernel is diferent
And right after it
# cd /bin
# ln -s bash sh
cheers
09-15-2009 12:21 PM
why do i need
i have the headers installed for my kernel 2.6.28-15-general
09-15-2009 04:56 PM
HI
Sorry, you need the headers for your kernel. In your case.
apt-get install linux-headers-2.6.28-15-general
did you install?
What happens after...?
# ./updateNIDrivers
Reboot? yes
Let me see the errors messages?
Did you download the version download NI-488.2-beta-2.5 ?
Sorry if I seem a little paranoid.
Regards
