Hi all, i have several vi's that i use on windows and linux. Unfortunately i have to change font sizes styles to make them look correct in Linux (Either manually or using property nodes...) Is there anyway to avoid doing this?
I have the same problem on LabWindows for Linux. I researched it extensively, but there are several susbsystems that manage fonts for Linux and I could not figure out which one NI uses (I don't know if LabView uses the same as LabWindows, but it's likely). One hint is that if you launch the font selector available in NI products/APIs you don't get the same list as in your system or in pure X11. And in addition it varies not only between distros but also between different installs...
