08-07-2019 12:45 AM
Hi NI Team,
Can someone help me advise where can I get a driver installed needed for my NI-DAQmx model NI-6509 card. I've opened a site but I only found version 15.0 for Linux Redhat 6.9. Your help is a greatly approciated.
thanks,
Dexter
08-07-2019 06:43 AM
I am also try to get the NI-DAQmx base 15.0 for linux and the NI VISA for linux. But it's no way to get from NI download page.
if anybody no any information, please contact me.
Best wishes,
Zhongliang
08-07-2019 10:47 AM
@Dex123 wrote:
Hi NI Team,
thanks,
Dexter
Use the 2018 stack.
Install the RPM for RHEL6, then you should be able to just "yum install ni-daqmx".
08-07-2019 07:53 PM
Thanks for the info. I 'll try this.
08-08-2019 02:37 AM
For more information, please check the documentation below:
Please note that the installation repo is hosted online and the desktop Linux would need internet access to install the repo.
At the same time, RHEL user would need subscription to install the required dependencies.
DISCLAIMER: The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
08-08-2019 04:42 AM
Hi ZY_Ong,
Thank you. That't the things that I am currently working at with our IT Team now - to allow an Internet connection with my machine. I will let you know the results once I got net connection working.
