04-18-2020 10:10 PM
Create the package.xz using PKGBUILD to install "vipm-17.0.2018-1-x86_64.tar.xz - VI Package Manager (VIPM)" on Arch Linux and Manjaro Linux Distro.
VIPM for Linux must be run with admin or root level privileges. There is no way around this. If you run VIPM as a standard user, it will not work as expected and will generate errors. To do this, navigate to the installation folder at /usr/local/JKI/VIPM and execute the following: $ sudo ./vipm You will be prompted for your root password. Enter the password and VIPM will launch. If you need help with VIPM, visit our Community Forums at https://forums.jki.net
Access the following link "https://vipm.jki.net/download" and select the package for Linux, you must indicate an email to access the download, after downloading the package "vipm-17.0.2018-linux. tar.gz "copy it to the root of the PKGBUILD folder. Right there open a command terminal and run "$ makepkg -sri", once the package is compiled it will ask you for the superuser key to install the package in your Arch Linux or Manjaro Linux distribution.
You can manually check the hash of the file "vipm-17.0.2018-linux.tar.gz" once downloaded from the VIPM server, it would be the following hash SHA256SUM 'e105211c39b207cae2c1c0d1fca05fe09364890b420a7e8493e1df46f53db373'. (also the PKGBUILD verifies it automatically)
2020.04.12 ->
__________________________________________________
VIPM-2017 compilación de paquete para Arch Linux y Manjaro Linux, mediante pkgbuild. FUNCIONAL y probado junto con LabVIEW-2018-SP1 (español)
Estimados colegas, a continuación les comento que he logrado hacer correr VIPM-2017 en Manjaro Linux (derivada de Arch Linux).
Adjunto enlace a mi repositorio en Github para que puedan "Clonar y Descargar". (en el archivo readme.md se encuentra una guía)
https://github.com/oschiant/pkgbuild_vipm-2017_Arch-Linux
Mucho gusto ser parte de esta comunidad y espero que funcione este paquete para ustedes!!!
___________________________________________________________________________
VIPM-2017 package compilation for Arch Linux and Manjaro Linux, using pkgbuild. FUNCTIONAL and tested together with LabVIEW-2018-SP1
Dear colleagues, below I tell you that I have managed to run VIPM-2017 in Manjaro Linux (derived from Arch Linux).
Attached link to my repository on Github so they can "Clone and Download". (a guide is in the readme.md file)
I am delighted to be part of this community and I hope this package works for you.
04-19-2020 08:36 AM
what's new
2020.04.18
zensu
package to be able to run vipm
as superuser using the icon that is added to the Gnome applications. The user must belong to the wheel
group to be able to run vipm
in superuser mode. You can verify this by pasting the following command into a $ groups $ USER
console.
- In the future the idea is to run vipm as superuser using a polkit rule since it is the native authentication method of most graphical environments. See the following link https://wiki.archlinux.org/index.php/Polkit.
Running vipm from gnome:
With this update, there would be no need to run vipm from a console. (consider that it should be added to the Wheel group)
Good luck!!
