03-21-2019 11:39 AM
I don't know if this is the proper Forum, but I'm trying to build a kernel module which uses DAQmx in a CentOs7.5. So far I've installed DAQmx for linux and successfully built an user space application given as an example by NI and I've tried to build a similar application in kernel space. When I tried to compile that I got this message :
"WARNING: "DAQmxStopTask" [...] undefined!"
I know that this message normally happens if a dependence is not properly set or loaded, but I know, through lsmod, that ni's modules are loaded in my machine, so I'd like to know how to proper interface DAQmx to a kernel module.
For reference, here is my code
#include <linux/module.h> #include <linux/init.h> #include <linux/kernel.h> #include <linux/proc_fs.h> #include <linux/stringify.h> #include <linux/cdev.h> #include <asm/io.h> #include <NIDAQmx.h> MODULE_LICENSE("GPL"); MODULE_AUTHOR("Victor Costa"); MODULE_DESCRIPTION("DAQMX_LOADER using drivers"); MODULE_VERSION("0.1"); static int error=0; static char errBuff[2048]={'\0'}; static TaskHandle taskHandle=0; static double data[1000]; static void error_handler(void); static int CVICALLBACK DoneCallback(TaskHandle taskHandle, int status, void *callbackData); #define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else static int __module_init (void) { printk(KERN_DEBUG "DAQMX<1>: Loading Module\n"); for(int i=0;i<1000;i++) data[i] = 9.95; DAQmxErrChk (DAQmxCreateTask("",&taskHandle)); DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ao0","",-10.0,10.0,DAQmx_Val_Volts,NULL)); DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000)); DAQmxErrChk (DAQmxRegisterDoneEvent(taskHandle,0,DoneCallback,NULL)); /*********************************************/ // DAQmx Write Code /*********************************************/ DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,1000,0,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL)); /*********************************************/ // DAQmx Start Code /*********************************************/ DAQmxErrChk (DAQmxStartTask(taskHandle)); Error: error_handler(); return 0; } static void __module_exit (void) { printk(KERN_DEBUG "DAQMX<1>: Unloading Module\n"); } module_init(__module_init); module_exit(__module_exit); static void error_handler(void) { if( DAQmxFailed(error) ) DAQmxGetExtendedErrorInfo(errBuff,2048); if( taskHandle!=0 ) { /*********************************************/ // DAQmx Stop Code /*********************************************/ DAQmxStopTask(taskHandle); DAQmxClearTask(taskHandle); } if( DAQmxFailed(error) ) printk(KERN_DEBUG"DAQMX<1> Error: %s\n",errBuff); } static int CVICALLBACK DoneCallback(TaskHandle taskHandle, int32 status, void *callbackData) { char errBuff[2048]={'\0'}; // Check to see if an error stopped the task. DAQmxErrChk (status); Error: if( DAQmxFailed(error) ) { DAQmxGetExtendedErrorInfo(errBuff,2048); DAQmxClearTask(taskHandle); printk(KERN_DEBUG"DAQMX<1> Error: %s\n",errBuff); } return 0; }
