01-29-2019 02:46 PM
I'm pretty new to linux, and to NI. I have a USB-6009 and I would like to use it with linux. The readme for the NI-DAQmx 18.1 linux driver doesn't seem to list any USB devices, so I was wondering if it was even possible to use the USB-6009 in linux.
Is my only option to use the very outdated DAQmxBase 15? That would require that I downgrade my OS and mess around with 4-year-old libraries.
01-29-2019 03:48 PM - edited 01-29-2019 03:52 PM
At the moment, there is no ability to use any USB DAQ hardware with the newer DAQmx drivers on Linux.
DAQmx Base 15 is the currently the best/only option for using that hardware in Linux.
Check out the DAQmx Base compatibility matrix though. It should support the current versions of CentOS and RHEL.
01-29-2019 04:45 PM - edited 01-29-2019 04:46 PM
Thanks. I'll have to look at switching from SUSE. I wasn't aware of that matrix.
03-08-2021 09:44 PM
Has Linux support enabled USB device recognition since the Jan 2019 posts saying it was not available yet?
Specifically should nismbioscached work and create the USB device table in /run/nipxips/smbios/smbiosdmp ?
If yes, what opensuse version and ni-daqmx version?
I am on openSuse 15.2 and ni-daqmx version 20.1.
