07-13-2015 09:28 PM
Hello all,
I'm trying to down load the drivers to use this DAQ http://sine.ni.com/nips/cds/view/p/lang/en/nid/212383 within Linux mint on my 32bit computer. I'm a electro mechanical guy that programs (a lot) in basic C and doesn't know much about drivers and installing libraries. My end goal is to interface the DAQ with a C program. I have written C programs that talk to microprocessors successfully. Can anyone lay out the steps I need to take to get this to work (assuming it is possible). Thanks every one like I said I'm new to drivers and that kind of computer problems.
Effort so far:
I down loaded NI-DAQmx 8.0.2 - RedHat, SUSE http://www.ni.com/download/ni-daqmx-8.0.2/2322/en/
mounted it with: “sudo mount -t iso9660 -o loop DAQmx802f0.iso <mount location>”
then ran: “./INSTALL” like it says.
But I get this message:
*********************************** ERROR ***************
* ERROR: 3.11 kernels are not supported! *
* Running a 2.6.x kernel is required to continue this installation. *
any ideas?
07-14-2015 02:43 AM
error message said you are running on kernel 3.11, but kernel 2.6.x is required.
Basicly, if you want to use NI-DAQmx 8.0.2 you should use RHEL/Scienfitific Linux or CentOS 6.x or some other old rpm based Linux distribution (Suse, Mandrake/Mandriva) or deb (with some complications).
There is an alternative driver NI-DAQmx Base, which you can use with rpm or deb (with some complications) based distribution with linux kernel up to 3.2 or 3.4 (I think): RHEL/Scientific Linux/CentOS 6.x (kernel 2.6.x) or OpenSuSe 13.2 or Mageia 2 (kernel 3.2-3.4).
Now, modern Linux distribution are not supported, only interprised based RHEL and it clones Scientific Linux, CentOS.
USB-6001 is not supported under Linux.
You can use NI-DAQmx Base 14.0
http://http://http://www.ni.com/download/ni-daqmx-base-14.0/5054/en/
with card from list in readme.
07-14-2015 02:57 AM
Dear scootergarrett,
mig-31 is right. I nevertheless may try to help you.
I need two things:
1-The exact Linux distribution which you use.
2-The complete terminal output (one long line) for command uname -a
Cheers
Yanqele
07-15-2015 09:47 PM
Mig-31,
so your saying I'm using the wrong distribution of Linux, but maybe I could use 'NI-DAQmx Base 14.0'?
yanqle,
I got the exact Linux distribution with the command 'cat /etc/*-release' and got:
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=16
DISTRIB_CODENAME=petra
DISTRIB_DESCRIPTION="Linux Mint 16 Petra"
NAME="Ubuntu"
VERSION="13.10, Saucy Salamander"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 13.10"
VERSION_ID="13.10"
HOME_URL="http://www.ubuntu.com/"
SUPPORT_URL="http://help.ubuntu.com/"
BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/"
Then I ran 'uname -a' and got:
Linux garrett-pro135115 3.11.0-12-generic #19-Ubuntu SMP Wed Oct 9 16:12:00 UTC 2013 i686 i686 i686 GNU/Linux
Thanks everyone for your help
07-16-2015 03:35 AM
probably you can use NI-DAQmx Base 14.0 with your Linux Mint (Open SuSe 13.1 use kernel 3.11.x same as Linux Mint).
In case of USB DAQ card there is only one possibility NI-DAQmx Base 14.0
07-16-2015 08:39 AM
The USB-6001 (and 6000, 6002, and 6003) are unfortunately not supported by NI-DAQmx Base. If you need a low-cost USB DAQ device for use with Linux or Mac OS X, you will need to use the USB-6008 or USB-6009.
03-04-2018 12:36 PM
Except for really ancient and totally unsupported kernels, proprietary drivers for USB devices are illegal (IOW: you'll loose the license to use Linux at all) - the driver *must* be GPL. (unless you'll write your completely own USB stack and remove the built-in one).
But NI still insists in always unstable and hazardous (yes! expect data loss and maybe even hardware damage) proprietary drivers, so they just can't support any USB devices on not-ancient kernels.
By the way one of the reasons why my clients will *NOT* invest several mio in NI hardware.
