Linux Users
Problem launching VIPM on openSUSE 15.1
I have installed openSUSE 15.1 on my laptop and on a VM.  In both cases, I am unable to launch VIPM.  When I try, an error message comes up:  Unable to open x display.
I have confirmed this behavior with both the Wayland and Xorg x servers (echo $XDG_SESSION_TYPE).
I have been successful in using VIPM with CentOS.  However, I would prefer to use openSUSE if possible.  If anyone has any suggestions, I would be open to trying them.  Please keep in mind that I am new to Linux, so please be patient with me.  Also, whatever I need to do to transition over to Linux for development will be better than what I am enduring using Windows.
Thank you!
Message 1 of 9
(1,243 Views)
Additional Information:
I installed openSUSE 15.1 (Desktop with KDE Plasma), then followed the instructions here to install support for LabVIEW 2015RTE 32-bit.  After extracting the archive files, I moved the /JKI/ directory to /usr/local/.  After running the INSTALL script, the message Installation Completed comes up, and no errors or warnings were displayed during the process.  I changed to the /usr/local/JKI/VIPM directory and entered 'sudo ./vipm' and the message "Unable to open X display" appears.  After typing 'echo $XDG_SESSION_TYPE' the response is "x11".
Message 2 of 9
(1,214 Views)
Hello DLJ,
Did you ever get this resolved?
I have the same issue as you and would appreciate your help.
Warmest Regards,
HoSsEiN
Message 3 of 9
(1,165 Views)
After some tinkering, I finally found a work-around for this problem.  Please keep in mind that I have just installed openSUSE as an operating system, and as such I did not have any personal files at risk here.
I downloaded and installed openSUSE 15.0 on my laptop.  After getting all of the updates, I followed the previous instructions to install the additional 32bit related packages.  Then I installed VIPM.  Please note the following responses from the terminal window:
     User Terminal:  Command: sudo ./vipm       Response:  Unable to open X display
     User Terminal:  Command: ./vipm      Response:  Do not have permission to open file
     Root Terminal:  Command: sudo ./vipm      Response: Unable to open X display
     Root Terminal:  Command: ./vipm      Response:  VIPM opens successfully!!
Once I verified that VIPM would open, I used a USB with the openSUSE Leap 15.1 installation files.  When the screen pops up, I selected UPDATE instead of INSTALL or BOOT FROM HARD DRIVE (see example here).  After selecting all of the default values, the system updated to Leap 15.1.  After rebooting, I verified that Leap 15.1 was installed, and checked for any additional updates.  Once that was done, I was able to successfully launch VIPM as root from a terminal window (see above responses).
I tested the above on a virtual machine first.  As an alternative, I used the example found here on the VM as well, with success in launching VIPM, though it was not the method I used to update my laptop.
For some reason, starting from a fresh install of Leap 15.1 does not allow VIPM to run.  When trying to launch, I get the Fatal Error 0x90FFFA4E error.  This has been the only way that I have been able to successfully launch VIPM in openSUSE 15.1.
I hope that this works for you!
Message 4 of 9
(1,146 Views)
Hello DLJ,
thanks for the follow up.
I've installed LV RT and the librarys mentioned, but unfortunatly I still can't launch VIPM.
Second is the Terminal -Superuser Mode. Is that what you meant with Root Terminal?
Any other ideas?
Message 5 of 9
(1,115 Views)
Alex-
Please remember, I started with a fresh install of openSUSE 15.0, then installed VIPM.  Once VIPM was installed and successfully running, only then did I upgrade to openSUSE 15.1.  Whenever I installed VIPM on 15.1, I always received the error you attached.
When installing VIPM, I opened Konsole, and then switched to root using su root.  From there, I installed and ran VIPM.
If you can, I would suggest reinstalling openSUSE 15.0, installing VIPM, and then upgrading to 15.1.  Another option might be to downgrade to 15.0 and reinstall VIPM.  However, I have not tried this, so I cannot speak to its success.
Message 6 of 9
(1,105 Views)
Thank you for the clarification! I didn't read it carefully the first time. After Installing openSUSE 15.0 instead of 15.1 and following the procedere VIPM is starting now.
Message 7 of 9
(1,062 Views)
I had the same problem using OpenSuse Leap 15.2
1) When I tried to run vipm using the command sudo ./vipm the error message Unable to open X display was shown.
2) When I tried to run vipm using ->./vipm (without sudo) the VIPM window pops up and then closes after few seconds.
3) When I tried to run vipm using -> gnomesu ./vipm the VIPM opens normally.
I found the hint in the following link -> https://forums.opensuse.org/showthread.php/405624-sudo-doesnt-open-X-programs
Message 8 of 9
(393 Views)
I have the same problem but I cannot downgrade or reinstall openSUSE 15.1.
At this page https://resources.jki.net/en/vipm-2020-download
"VIPM 2020 for Mac and Linux are not yet released. Stay tuned."
So I wait for news for direct use VIPM on openSUSE 15.1 or for a new release of VIPM
thank you all
Message 9 of 9
(384 Views)
