10-08-2019 09:28 AM
I have installed openSUSE 15.1 on my laptop and on a VM. In both cases, I am unable to launch VIPM. When I try, an error message comes up: Unable to open x display.
I have confirmed this behavior with both the Wayland and Xorg x servers (echo $XDG_SESSION_TYPE).
I have been successful in using VIPM with CentOS. However, I would prefer to use openSUSE if possible. If anyone has any suggestions, I would be open to trying them. Please keep in mind that I am new to Linux, so please be patient with me. Also, whatever I need to do to transition over to Linux for development will be better than what I am enduring using Windows.
Thank you!
10-09-2019 07:53 AM
Additional Information:
I installed openSUSE 15.1 (Desktop with KDE Plasma), then followed the instructions here to install support for LabVIEW 2015RTE 32-bit. After extracting the archive files, I moved the /JKI/ directory to /usr/local/. After running the INSTALL script, the message Installation Completed comes up, and no errors or warnings were displayed during the process. I changed to the /usr/local/JKI/VIPM directory and entered 'sudo ./vipm' and the message "Unable to open X display" appears. After typing 'echo $XDG_SESSION_TYPE' the response is "x11".
11-20-2019 03:05 AM
Hello DLJ,
Did you ever get this resolved?
I have the same issue as you and would appreciate your help.
Warmest Regards,
HoSsEiN
12-02-2019 03:47 PM
After some tinkering, I finally found a work-around for this problem. Please keep in mind that I have just installed openSUSE as an operating system, and as such I did not have any personal files at risk here.
I downloaded and installed openSUSE 15.0 on my laptop. After getting all of the updates, I followed the previous instructions to install the additional 32bit related packages. Then I installed VIPM. Please note the following responses from the terminal window:
User Terminal: Command: sudo ./vipm Response: Unable to open X display
User Terminal: Command: ./vipm Response: Do not have permission to open file
Root Terminal: Command: sudo ./vipm Response: Unable to open X display
Root Terminal: Command: ./vipm Response: VIPM opens successfully!!
Once I verified that VIPM would open, I used a USB with the openSUSE Leap 15.1 installation files. When the screen pops up, I selected UPDATE instead of INSTALL or BOOT FROM HARD DRIVE (see example here). After selecting all of the default values, the system updated to Leap 15.1. After rebooting, I verified that Leap 15.1 was installed, and checked for any additional updates. Once that was done, I was able to successfully launch VIPM as root from a terminal window (see above responses).
I tested the above on a virtual machine first. As an alternative, I used the example found here on the VM as well, with success in launching VIPM, though it was not the method I used to update my laptop.
For some reason, starting from a fresh install of Leap 15.1 does not allow VIPM to run. When trying to launch, I get the Fatal Error 0x90FFFA4E error. This has been the only way that I have been able to successfully launch VIPM in openSUSE 15.1.
I hope that this works for you!
12-12-2019 04:53 AM
Hello DLJ,
thanks for the follow up.
I've installed LV RT and the librarys mentioned, but unfortunatly I still can't launch VIPM.
Second is the Terminal -Superuser Mode. Is that what you meant with Root Terminal?
Any other ideas?
12-12-2019 09:32 AM
Alex-
Please remember, I started with a fresh install of openSUSE 15.0, then installed VIPM. Once VIPM was installed and successfully running, only then did I upgrade to openSUSE 15.1. Whenever I installed VIPM on 15.1, I always received the error you attached.
When installing VIPM, I opened Konsole, and then switched to root using su root. From there, I installed and ran VIPM.
If you can, I would suggest reinstalling openSUSE 15.0, installing VIPM, and then upgrading to 15.1. Another option might be to downgrade to 15.0 and reinstall VIPM. However, I have not tried this, so I cannot speak to its success.
01-09-2020 02:48 AM
Thank you for the clarification! I didn't read it carefully the first time. After Installing openSUSE 15.0 instead of 15.1 and following the procedere VIPM is starting now.
11-19-2020 07:12 AM
I had the same problem using OpenSuse Leap 15.2
1) When I tried to run vipm using the command sudo ./vipm the error message Unable to open X display was shown.
2) When I tried to run vipm using ->./vipm (without sudo) the VIPM window pops up and then closes after few seconds.
3) When I tried to run vipm using -> gnomesu ./vipm the VIPM opens normally.
I found the hint in the following link -> https://forums.opensuse.org/showthread.php/405624-sudo-doesnt-open-X-programs
11-19-2020 08:32 AM
I have the same problem but I cannot downgrade or reinstall openSUSE 15.1.
At this page https://resources.jki.net/en/vipm-2020-download
"VIPM 2020 for Mac and Linux are not yet released. Stay tuned."
So I wait for news for direct use VIPM on openSUSE 15.1 or for a new release of VIPM
thank you all
10-26-2021 08:05 AM - edited 10-26-2021 08:13 AM
I'm having the same issue on my OpenSuse Leap 15.1
I installed LabVIEW RTE 2015 SP1 and VIPM
Then libXinerama.so.1 was missing, so I installed it manually
Then LibGL was missing, so I installed it manually
And now I'm stuck on this "Unable to open X display"
I've tried user and root with and without "sudo", no luck.
Then I installed gnomesu ($ sudo zypper install libgnomesu)
And now when I run "gnomesu ./vipm", I get this :
(gnomesu:13270): Gtk-WARNING **: gtk_window_set_titlebar() called on a realized window
Gtk-Message: GtkDialog mapped without a transient parent. This is discouraged.
Fatal Internal Error 0x90FFFA4E : "AppEntryPoint.cpp", line 86
LabVIEW version 15.0.1f13
You will lose any unsaved work. For assistance in resolving this problem, please relaunch LabVIEW, or contact National Instruments.
Anyone solved this?
Epictetus
