07-08-2009 11:10 AM
Hello everybody,
I'm novice in linux environment 😞 and I'm trying to install on OpenSuse 11.0:
- NI LabVIEW 8.6.1
- NI DAQmx 8.0.1
- NI KAL 1.9
All installations are complete and successfull.
I have made an update of NI Drivers.
But, when I open the terminal and type
nilsdev
I encounter the error below:
"libnipalu.so failed to initialize
Perhaps you need to run updateNIDrivers
Aborted"
I have read the different messages on NI Developer Zone but no solution should be help me for the moment.
I need install 3 NI PCI Cards (NI PCO-6229 and NI PCI-6703) ...
Thank you for your help
Yann
07-08-2009 11:30 AM
Have you tried to run updateNIDrivers? If so what did it say? Did you get any errors? Note you will need to run updateNIDrivers using su or sudo or as the root user. After running it you will need to reboot the machine.
Neil
07-09-2009 12:36 AM
Hej,
Yes, I have run the "updateNIDrivers". All updates are successfull. Reboot is OK ...
All actions have been made on SU profile.
An another error is when I launch LabVIEW, create a new VI and use a DAQmx VI, LabVIEW Crashes ...
Thks
07-09-2009 07:53 AM
How much RAM do you have in your system?
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
07-09-2009 08:05 AM
RAM < 4 GB
I have read the application Note on NI web site.
07-09-2009 08:10 AM
Very well, would you like us to continue guessing what could be happening, or would you like to provide us with more information? Perhaps you could have even told us which DevZone articles you read...
What messages do you see in your kernel/dmesg logs about NI modules?
What is the console output for updateNIDrivers?
Joe Friedchicken
07-09-2009 08:17 AM
I'm sorry but, even if, I post a message on the forum, I continue working because my customer do not wait ... 😄
But I'm really sorry, I could send you all informations before 😞
What messages do you see in your kernel/dmesg logs about NI modules? -> what this ?
What is the console output for updateNIDrivers? I send you the output file.
07-13-2009 03:37 PM
Attaching the output of niSystemReport would be useful. Just "su" to become root then run:
niSystemReport > report.log
gzip report.log
Then attach the report.log.gz file to your forum post.
Shawn Bohrer
07-16-2009 01:33 AM
Hej,
I attached the result of Update NI Drivers. I hope that it can help you
Thks
07-16-2009 01:34 AM
Hej,
I attached the result of Update NI Drivers. I hope that it can help you.
Thks
