Linux Users
Reply
OpenSuse 11.1 64Bit and NI-488.2 Installation Problems GCC
Hi, i have 2 Questions
1:  I read somewhere here that nikal dont run on a System with more then 4GB RAM , is this still true ? Becouse my System have 6 GB RAM
2:
I try to install the NI-488.2 on the OpenSuse 11.1 64bit with the Kernel linux-2.6.27.29-0.1.
I use the NI-488.2 2.5 Beta 64 Bit Driver.
After the sh ./INSTALL i get this error:
Continue? [Yn] Y
Checking required install tools...
Checking installer tool versions...
rpm        4.4.2.3 can be used with a default installation path
tar        1.20
Checking dependencies...
glibc      2.9
Unpacking install files to /tmp/NI4882-2.5.4b1.install...
******************************** ERROR ****************************************
* The version of gcc in the path does not match the version of gcc used to    *
* compile the currently running kernel.  This can cause unpredictable         *
* behavior in kernel drivers and should be fixed.                             *
* gcc version: Linux)                                                          *
* kernel compiled with: 4.3.2                                                 *
I cheked the Version of the GCC with gcc -v and its the same Version
Using built-in specs.
Target: x86_64-suse-linux
Configured with: ../configure --prefix=/usr --infodir=/usr/share/info --mandir=/usr/share/man --libdir=/usr/lib64 --libexecdir=/usr/lib64 --enable-languages=c,c++,objc,fortran,obj-c++,java,ada --enable-checking=release --with-gxx-include-dir=/usr/include/c++/4.3 --enable-ssp --disable-libssp --with-bugurl=http://bugs.opensuse.org/ --with-pkgversion='SUSE Linux' --disable-libgcj --disable-libmudflap --with-slibdir=/lib64 --with-system-zlib --enable-__cxa_atexit --enable-libstdcxx-allocator=new --disable-libstdcxx-pch --enable-version-specific-runtime-libs --program-suffix=-4.3 --enable-linux-futex --without-system-libunwind --with-cpu=generic --build=x86_64-suse-linux
Thread model: posix
gcc version 4.3.2 [gcc-4_3-branch revision 141291] (SUSE Linux)
I tryed the solution here on the site. But it doesn help to edit the installerUtility.sh
I just get annother GCC error
By installing this software, you are acknowledging acceptance of the terms
of the included license file (LICENSE.txt).
Do you accept the license? [ynq] Y
linux-sapt:/home/hplogger/Desktop/release # sh ./install
  NI-488.2 Distribution
     version 2.5.4b1 for Li  ########################################### [ 43%]
   4:ni4882ki               ########################################### [ 57%]
   5:labview82-rte          ########################################### [ 71%]
   6:nispyi                 ########################################### [ 86%]
   7:ni4882i                ########################################### [100%]
Post Installation .
Warning: nikali post installation failed! /tmp/nikaliPostInstall.log follows:
./uninstall.sh: line 13: Makefile.in: Datei oder Verzeichnis nicht gefunden
Makefile:11: Makefile.in: Datei oder Verzeichnis nicht gefunden
make: *** Keine Regel, um »Makefile.in« zu erstellen.  Schluss.
Updating NI-KAL:
NI-KAL update failed.
ERROR: make of nikal kernel module failed, not installing kernel module.
   updateNIDrivers should be called again after fixing the problem.
   Logging failure...
   Include the file /tmp/niSystemReport.out.gz when contacting
   National Instruments for support.
FOR PATENTS COVERING NATIONAL INSTRUMENTS PRODUCTS, REFER TO
THE PATENTS.txt FILE ON /home/hplogger/Desktop/release AND/OR
www.ni.com/patents
* A reboot is required before attempting to use the
* NI-488.2 Distribution software.
Would you like to reboot now? [yes|no] N
Please input yes or no.
Would you like to reboot now? [yes|no] no
NI-488.2 Distribution Installation completed with errors.
Please reboot manually before attempting to use
What else can I try to finish the installation ?
(5,943 Views)
Re: OpenSuse 11.1 64Bit and NI-488.2 Installation Problems GCC
1.  The 4GB of RAM limitation is only on 32-bit Linux.  64-bit Linux does not have this limitation.
2.  Installing the latest version of NI-KAL (Currently 1.10) then re-running the NI-488.2 INSTALL script should fix your problem.
Shawn Bohrer
Use NI products on Linux? Come join the NI Linux Users Community
(3,952 Views)
THX, very much. I will try it when I am back at work.
But is there anything that i should know, take care of any previous steps.
Just use the original installation script or the modifed script ?
And my first question was based on this KnowledgeBase etry " NI-KAL Fails to Load When I Have Greater Than 4GB of RAM " http://digital.ni.com/public.nsf/allkb/20789C3E4A3DCAFB8625708B00693CF9
is this problem solved in the new driver ?
(3,952 Views)
Highlighted
That KnowledgeBase still applies for 32-bit installations.  When installing NI-KAL and drivers that support 64-bit (NI-488.2 and NI-VISA) you will not have the 4GB limitation.
I assume at this point you have things installed, either by going back through installation after installing NI-KAL 1.10 or by running updateNIDrivers.
(3,952 Views)
Reply
