Linux Users
Reply
Highlighted
Need Help! nilsdev returns errors from Kernel
OS: OpenSuSE  11.4
Kernel: Linux 2.6.37.1-1.2-default #1 SMP 2011-02-21 10:34:10 +0100 i686 i686 i386 GNU/Linux
Installed NIDAQmx from DAQmx802f0.iso
Installation was successful with no errors, ran updateNIdrivers upon completion and no errors. Rebooted system.
NI Boards Installed: PXI-6534, PXI-6221, PXI-6052E
Results of lspci show 3 NI boards:
03:0d.0 Unassigned class [ff00]: National Instruments Device 70b5
03:0e.0 Unassigned class [ff00]: National Instruments PXI-6052E
03:0f.0 Unassigned class [ff00]: National Instruments Device 1490 (rev 01)
Ok, so here is where the problem comes in. When I run nilsdev or try to execute a command to read from any of the cards, I get the following errors:
Message from syslogd@dtags at Jul  6 14:02:27 ...
kernel:[ 7038.537247] Oops: 0000 [#10] SMP
kernel:[ 7038.537255] last sysfs file: /sys/devices/pci0000:00/0000:00:1e.0/0000:02:0c.0/0000:03:0f.0/class
kernel:[ 7038.537395] Process ni (pid: 3835, ti=f4c40000 task=f597c1f0 task.ti=f4c40000)
kernel:[ 7038.537403] Stack:
kernel:[ 7038.537448] Call Trace:
kernel:[ 7038.537531] Code: 10 00 39 d9 72 0e 01 c0 83 ea 01 75 ef 31 c0 5b c3 8d 76 00 b8 01 00 00 00 5b c3 89 f6 8d bc 27 00 00 00 00 53 83 ec 0c 8b 5a 74 <8b> 03 8b 00 8b 00 8b 50 24 b8 ea ff ff ff 85 d2 75 07 83 c4 0c
kernel:[ 7038.537580] EIP: [<f806a0e7>] nNIKAL100_ioctl+0x7/0x40 [nikal] SS:ESP 0068:f4c41f68
kernel:[ 7038.537596] CR2: 000000003cbe0d06
results of lsmod | grep ni:
nissrk               2037379  0
nisftk                287513  0
nixsrk               1682087  0
nitiork               996103  2 nissrk,nixsrk
nispdk                 59427  0
niesrk               1014092  1 nispdk
niwfrk                852488  0
nidsark              1439468  0
nistcrk               182993  4 nissrk,niesrk,niwfrk,nidsark
nistc2k               225821  5 nissrk,niesrk,niwfrk,nidsark,nistcrk
nisdigk               435038  2 nixsrk,niesrk
niswdk                960723  0
niscdk               1095106  2 nispdk,niswdk
nicdrk                365202  9 nissrk,nixsrk,nitiork,niesrk,niwfrk,nistcrk,nisdigk,niswdk,niscdk
nimxpk                 33664  12 nissrk,nixsrk,nitiork,niesrk,niwfrk,nidsark,nistcrk,nistc2k,nisdigk,niswdk,niscdk,nicdrk
nimru2k               427929  12 nissrk,nisftk,nixsrk,nitiork,nispdk,niesrk,niwfrk,nidsark,nistcrk,nisdigk,niswdk,niscdk
nipxirmk              115098  0
nidimk                320663  5 nitiork,niswdk,niscdk,nimru2k,nipxirmk
nimsdrk               231290  8 nissrk,nisftk,nixsrk,nitiork,niesrk,niwfrk,nidsark,nistcrk
nidmxfk               373992  11 nissrk,nisftk,nixsrk,nitiork,niesrk,niwfrk,nistcrk,nisdigk,niscdk,nicdrk,nimsdrk
nimxdfk               477960  16 nissrk,nisftk,nixsrk,nitiork,nispdk,niesrk,niwfrk,nidsark,nistcrk,nisdigk,niswdk,niscdk,nicdrk,nimru2k,nimsdrk,nidmxfk
nimstsk                78221  14 nissrk,nisftk,nixsrk,nitiork,niesrk,niwfrk,nidsark,nistcrk,nisdigk,niswdk,niscdk,nicdrk,nimsdrk,nidmxfk
nimdbgk               360264  19 nissrk,nisftk,nixsrk,nitiork,nispdk,niesrk,niwfrk,nidsark,nistcrk,nistc2k,nisdigk,niswdk,niscdk,nicdrk,nimru2k,nimsdrk,nidmxfk,nimxdfk,nimstsk
niorbk                 95711  21 nissrk,nisftk,nixsrk,nitiork,nispdk,niesrk,niwfrk,nidsark,nistcrk,nisdigk,niswdk,niscdk,nicdrk,nimru2k,nipxirmk,nidimk,nimsdrk,nidmxfk,nimxdfk,nimstsk,nimdbgk
nipalk               1225232  25 nissrk,nisftk,nixsrk,nitiork,nispdk,niesrk,niwfrk,nidsark,nistcrk,nistc2k,nisdigk,niswdk,niscdk,nicdrk,nimxpk,nimru2k,nipxirmk,nidimk,nimsdrk,nidmxfk,nimxdfk,nimstsk,nimdbgk,niorbk
nikal                  61078  1 nipalk
I've attached the report from the niSystemReport command...let me know if any additional info is needed.
Any suggestions to get this working???
Thanks!
Ed
(2,774 Views)
Should have looked a little further on the site. I found the answer in the following message:
I apologize for the situation guys. We know that Linux support is painful for our customers. Linux moves pretty fast, and we only have limited resources dedicated for Linux internally, and we have other obligations and priorities. It's hard to keep up with Linux kernel changes. And yes, we know that there are better ways to support Linux with open source drivers and such, but that also comes with other set of problems. Sigh.
Anyway, I got KAL on Open SUSE 11.4 working. We're going to merge the changes to the main KAL source.
In the meantime, here's the diff that you can try out:
@@ -241,6 +241,9 @@
static int nNIKAL100_open(nLinux_inode *the_inode, nLinux_fileHandle *filePtr);
static int nNIKAL100_release(nLinux_inode *the_inode, nLinux_fileHandle *filePtr);
static int nNIKAL100_ioctl(nLinux_inode *the_inode, nLinux_fileHandle *filePtr, unsigned int command, unsigned long param);
+#ifdef HAVE_UNLOCKED_IOCTL
+static long nNIKAL100_unlockedIoctl(nLinux_fileHandle *filePtr, unsigned int command, unsigned long param);
+#endif
#ifdef HAVE_COMPAT_IOCTL
static long nNIKAL100_compatIoctl(nLinux_fileHandle *filePtr, unsigned int command, unsigned long param);
#endif
@@ -512,7 +515,11 @@
.open = nNIKAL100_open,
.release = nNIKAL100_release,
+ .unlocked_ioctl = nNIKAL100_unlockedIoctl,
+#else
.ioctl = nNIKAL100_ioctl,
+#endif
.compat_ioctl = nNIKAL100_compatIoctl,
#endif
@@ -1798,6 +1805,13 @@
return status;
+ unsigned long param)
+ return (long)nNIKAL100_ioctl(NULL, filePtr, command, param);
+#endif
  1. Modify /usr/local/natinst/nikal/src/nikal.c using the diff above (manually, or using patch command). NOTE: Pay no attention to the line number. It's going to be different from your installed version. Look for similar lines and make the proper modifications.
  2. After that, I think you just need to run updateNIDrivers script
I've tested those changes, it seems to work.
I still don't know when the next official KAL release containing those changes will be released. We still need to discuss it internally to figure it out.
at least with this, you guys can make progress in parallel.
Post to this forum if you have prob. I'll try to answer.
Unfortunately, I can't attach files in here, otherwise, I'd have sent you guys the new kal file directly. Oh well.
Sorry again for the painful support here.
(1,045 Views)
Re: Need Help! nilsdev returns errors from Kernel
The core problem is that NI refuses to collaborate with the community. This makes the whole show extremely unstable, unreliable and expensive. Free drivers are the only practically usable solution.
That wouldn't be a problem with free drivers. The community would take care of that.
Which problems, exactly ? Developing a new IIO driver afresh would take about 4..8 weeks per device for a single kernel hacker. Very cheap compared with the extreme costs of maintaining proprietary drivers, that don't work reliably anyways.
The whole idea of an "kernel abstraction layer" is ridiculous to begin with.
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(385 Views)
Reply
