Linux Users
NI DAQmx on Ubuntu 22.04 with HWE?
I would like to use the NI-DAQmx on Ubuntu 22.04. It seems to work fine with the original kernel, v5.15 (to be precise, v5.15.0-91). However, if I use the newer kernel, from the "hardware enablement" stack, v6.5, the dkms modules fail to build. Essentially, when building nikal, it fails with:
  CC [M]  /var/lib/dkms/nikal/23.8.0f102/build/nikal.o
  MODPOST /var/lib/dkms/nikal/23.8.0f102/build/Module.symvers
ERROR: modpost: "__pte_offset_map" [/var/lib/dkms/nikal/23.8.0f102/build/nikal.ko] undefined!
make[2]: *** [scripts/Makefile.modpost:144: /var/lib/dkms/nikal/23.8.0f102/build/Module.symvers] Error 1
make[1]: *** [Makefile:1989: modpost] Error 2
This newer kernel does work better with my computer, so I'd rather use that one if possible. Is this error known? Is there already a plan to support this newer kernel soon?
Best,
Éric
(4,391 Views)
Accepted by pieleric
This is a known issue.  I would expect this to be corrected in the coming quarterly driver stack release.  In the mean time, if you can somehow use the 6.2 HWE kernel, that may work.
(4,384 Views)
@pieleric The landing page hasn't been updated yet (that's coming very soon), but the Linux driver feeds have been updated for 2024 Q1.   The top-level Ubuntu 22.04 package can be found here: http://download.ni.com/ni-linux-desktop/2024/Q1/ni-ubuntu2204-firstlook-drivers-2024Q1.deb
Edit: The landing page now has links to the 2024 Q1 drivers: https://www.ni.com/en/support/downloads/drivers/download.ni-linux-device-drivers.html
(4,123 Views)
