Linux Users
NI-DAQmx 22.5 RHEL 8.7 - PCIe-6321 not recognized
Trying to get a PCIe-6321 working in Linux Redhat 8.7 with LabVIEW 2019 and DAQmx 22.5.
nidaqmxconfig --export does not show the card.
When I ran
rpm -qa | grep -i daqmx
between this system running on a rack mount PC vs my RHEL9 PXIe based system, one of the differences we noted on the installed packages was
PXI running LV 2022 and DAQmx 22.5:
libnidaqmx-22.5.0.49254-0+f102.x86_64
libnidaqmx-labview-22.5.0.49255-0+f103.x86_64
Rack mount PC with LabVIEW 2019 and DAQmx 22.5:
libnidaqmx-labview-19.1.0.49154-0+f2.x86_64
We're unsure what the libnidaqmx-labview package does, and if it should match the LabVIEW version or the DAQmx version.  It seems plausible it should match the LabVIEW version.
Other than this we're at a loss as to understand why the PCIe-6321 is not being detected in the system in Linux using any of the tools.  I.e. lsni -v does not show the card.  nidaqmxconfig --export does not show the card.  lspci -v does not show the board.
Anything else we might check??
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(4,253 Views)
That's very strange.  Have you tried this board in other PCs or in other PCIe slots of this PC?  Have you tried lspci with the board present but with absolutely no NI software installed?
(4,213 Views)
It's not my system - but I will pass on the idea to try another PCIe slot.
(4,208 Views)
Thanks.  If the PCIe bus recognizes the device at all I'd expect to see it in lspci output.
(4,200 Views)
Yeah - we grabbed a generic PCIe Ethernet card and put it in the chassis as well just to verify the 2nd and 3rd PCIe risers would recognize another card and it wasn't just an issue with the NI card.  The system didn't recognize that card either.
We have some digging through the Dell 7920 manual to do it seems.  Only the first riser of 3 seems to be recognizing cards.
(4,163 Views)
Accepted by topic author RVallieu
The issue was that not all slots are available to a single CPU 7920 system.  Only slots 1, 2, 3 and 6 are available to CPU1 in a 7920.  6 unfortunately is only half-height, half-length compatible.  Luckily we had slot 2 open on Riser 1.   System recognizes the card!
(4,156 Views)
