Linux Users
NFS copy of filesystem used with pxeboot doesnt load daqmx device drivers
We are attempting to pxeboot a system based on our working RHEL 7.9 LabVIEW 2019 SP1 installation.
When we created the nfs image that the system uses using rsync we took everything but /proc and /sys and /home/installers (where we put package and iso images on our disconnected systems in case we need to install a package we forgot).
The system boots into RHEL 7.9 GNOME, autologin and autostart work to trigger the start of our LabVIEW EXE - but when my DAQmx device based code runs, it is telling me that the DAQmx driver basically has not been installed.  I get error -52006 when DAQmx Create Task.vi is called.
Anyone have experience with the NI DAQmx LabVIEW drivers in a pxeboot system that should run a LabVIEW EXE that can shed some light?
when I run
nidaqmxconfig --export /tmp/ni-system in the disk loaded image version I get the DAQmx cards listed in Slots 6, 7, 8, and 9
When I run from the pxeboot running the NFS image
shows
Failed
Error -52006
The requested resource was not located.
Edit to add: Coworker used the disk-booted FSP-4 system to collect all modules reported by lsmod that started with "ni" or "Ni", and created files in the rootfs on tftpboot Server for each in the directory /etc/modules-load.d/*.conf
We saw some suggestions that on systemd systems that this could work to load drivers.  This did not help.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Message 1 of 20
(7,912 Views)
Which (if any) NI kernel modules are being loaded on the failing system?  What happens if you try to load one manually (e.g., if nipalk is failing to load, modprobe nipalk)?  Anything interesting in dmesg or in /var/log/messages or using journalctl?
Message 2 of 20
(7,861 Views)
ah dmesg showed a failure of nikal module verification failed: signature and/or required key missing
Accordingt to NI: NI-KAL is driver software that supports the Linux driver architecture.
Seems like this could be the source of the issue.
Although lsmod shows nikal loaded....
lsmod | grep ni
ni448k
nicdcck
nicmrk
nicntdrk
nidimk
nifslk
nikal
nilmsk
nimdbgk
nimru2k
nimxdfk
niorbk
nipalk
nipxipfk
nipxirmk
nismbus
Message 3 of 20
(7,852 Views)
nikal is a fundamental module used by nearly every other NI kernel module.
The error message means that the kernel module is not signed properly for Secure Boot.  Unlike the kernel and all of the modules included with it, out-of-tree modules must be signed separately if you wish to use Secure Boot.  I can see a couple of scenarios:
  1. Secure Boot was not enabled on the original computer, so the kernel modules are completely unsigned.  Secure Boot is enabled on the new computer, so these binaries obviously fail the security checks.  You can use modinfo nikal to see whether the nikal module is signed.  If the modules are indeed unsigned, you have two options:
    1. Disable Secure Boot in the BIOS on the failing computer -or-
    2. Sign the kernel modules for Secure Boot
  2. Secure Boot was enabled on the original computer and the kernel modules are already signed.  If you wish to leave Secure Boot enabled on the new machine, I think you'd be able to just use mokutil on the new machines to register the public key that was used to sign the modules on the original machine.
Edit for future readers:  I was completely wrong about Secure Boot in this case.  See below.
Message 4 of 20
(7,843 Views)
I just saw this part.  Are other NI modules also shown as loaded?  Maybe the dmesg output was just a warning and not an error.
Message 5 of 20
(7,839 Views)
Was editing my prior post with the list.  Its a disconnected system so I have to type it out....
The one difference in loaded packages we see is NiVipciK did not load on the pxeboot system
Message 6 of 20
(7,836 Views)
did a modprobe NiPciViK and it seems to have loaded
Doing a reboot on the pxeboot and seeing if it is persistent.
Message 7 of 20
(7,831 Views)
NiViPciK is the VISA PCI/PXI Passport.  NI software should be configured to load it at boot normally.
Message 8 of 20
(7,827 Views)
It was persistent, but the DAQmx driver is still not loaded...
nidaqmxconfig --export /tmp/ni-system still shows error -52006 The requested resource was not found.
Message 9 of 20
(7,824 Views)
Looks like all of the modules shown in lsmod | grep ni from the disk booted system are now loaded when we do the pxeboot system - yet we still have the DAQmx driver error
Message 10 of 20
(7,817 Views)
