Linux Users
Install NI-Visa and PyVisa Ubuntu 14.04
I need to install NI-VISA and PyVisa on Ubuntu 14.04 (Ideally 5.4.1). Upon reading I hear that NI doesn't support Ubuntu. I have browsed a couple forums but I am having a hard time finding concrete instructions to follow in order to install NI-Visa on Ubunutu 14.04. I was wondering if someone could help point me in the right direction. I'm relatively new to Linux/Ubuntu. Any assitance is appreciated.
Message 1 of 8
(35,620 Views)
Anyone have any new info on this?  I am also attempting to get it to work on Ubuntu 14.04 and no luck so far
Message 2 of 8
(28,467 Views)
1) Download NI-VISA from [ http://www.ni.com/download/ni-visa-14.0/4797/en/ ]
2) then mound the .iso file
3) open the terminal and goto the mounted directory
4) type "sudo bash ./INSTALL" without ""
5) if dependencey error try with "sudo bash ./INSTALL --nodeps" without ""
6)done.
if it's succesfully installed
7) open another terminal and type "visaconf" it will open NI-VISA for you
Message 3 of 8
(28,467 Views)
Hi Vatpatel
I have the same problems as TS. Could you please explain me how you compile the nikal? I'm permanently getting error during compilation (see attachment).
I'm using the visa-5.4.1 & nikal-2.5.
P.S. May be I need to some kernel modules preparation as similar on openSUSE?
Thanks in advance,
Oleg
Message 4 of 8
(28,467 Views)
Hi.  As far as I can read from the Install script, this will not install on a Ubuntu machine.
What can you suggest for on what Ubuntu machine to convert this code to .deb files from rpm.
Thoughts?
Peter
Message 5 of 8
(28,467 Views)
instead use NI-VISA, you could use PyVisa-py
https://pyvisa-py.readthedocs.org
You can select the PyVISA-py backend using @py when instantiating the visa Resource Manager:
>>> import visa
>>> rm = visa.ResourceManager('@py')
>>> rm.list_resources()
('USB0::0x1AB1::0x0588::DS1K00005888::INSTR')
>>> inst = rm.open_resource('USB0::0x1AB1::0x0588::DS1K00005888::INSTR')
>>> print(inst.query("*IDN?"))
Message 6 of 8
(28,467 Views)
Joining in quite late to this.
I found it easier, to use the UI, and right mouse click and tell it to extract.  Then run from the resultant directory.  Since I am using ubuntu, I did need to use the --nodeps.
Fairly easy to do.
-- brett
Message 7 of 8
(28,307 Views)
Even After trying as you said, I got this error.... although I am not very much expert in linux, so please help me...
************************************ ERROR *************************************
* Kernel source does not appear to be installed for the 3.16.0-4-amd64 kernel.
*    Installation of the kernel-source package for kernel 3.16.0-4-amd64 is
*                   required to continue this installation.
Installer is aborted.
Message 8 of 8
(15,529 Views)
