09-25-2009 03:49 AM
Hi.
Currently working on a PXI4472.
I am trying to install DAQ8.1
My target board is diskless, so I boot OpenSuse 11.0 via PXE.
Most of the folders (e.g /bin /usr) are NFS Mounted with Read Only option.
So I install DAQ on the Server Machine.
This works fine.
When I exec nilsdev, it works (but I have no PXI board on the server machine)
When I exec nilsdev on the target board, I get an on libnipalu (libnipalu.so failed to initialize)
I tried to insmod the modules that were loaded in host machine but I still got the error on target board.
Any idea ?
Chris
ps : the UpdateNidrivers works only on host machine... On target it needs to write in Read Only folders...
09-25-2009 08:31 AM
Hi.
Well, managed to remove the error on nilsdev...
I just added "/etc/rc.d/nipal start" and the "libnipalu.so failed to initialize" is gone.
I still have an issue because the nilsdev reports no board .
On the host with the same board I get NI PXI-4472:"Dev1".
Help welcome !
09-25-2009 09:30 AM
Attaching reports of niSystemReport
One trace for the host where it works.
One trace for the target where it fails.
09-28-2009 03:03 AM
Hi
Made it works ...
On my target I start my own init so I don't run any script of the rc folders of the host...
If it can help someone, to make nilsdev work, it needs :
- To have the lo network interface configured (need to add /sbin/ifconfig lo 127.0.0.1)
- To have Write acces to /usr/local/ (need to write some file into a max folder)
- To start the following services or process :
/usr/local/natinst/max/sbin/nimxs /usr/local/natinst/max/libmxssvr.so
/usr/local/sbin/nipalsm /etc/natinst/nipal/services/libnidevldu.so.1.4.1
/usr/local/sbin/nipalsm /etc/natinst/nipal/services/libnipxirmu.so.1.6.0
Now the nilsdev show the plugged cards in my target system...
Chris
