01-02-2009 09:05 AM
HELP
I try to install NI-DAQmx 8.0.1 But I have this message :
******************************** ERROR ****************************************
* The version of gcc in the path does not match the version of gcc used to *
* compile the currently running kernel. This can cause unpredictable *
* behavior in kernel drivers and should be fixed. *
* gcc version: version gcc 4.2.2 20071128 (prerelease) (4.2.2%3.1mdv2008.0)
* kernel compiled with: 4.2.2 *
what can I do please ?
And how can I make Utility ?
My mandriva is :
[root@localhost DAQ]# cat /proc/version
Linux version 2.6.23 0.rc8.rt1.2mdvsmp (mandrake@n5.mandriva.com) (gcc version 4
.2.2 20070909 (prerelease) (4.2.2 0.RC.1mdv2008.0)) #1 SMP PREEMPT RT Thu Sep 27
and my GCC version is :
[root@localhost DAQ]# gcc v
Utilisation des specs internes.
Target: i586 mandriva linux gnu
Configuré avec: ../configure prefix=/usr libexecdir=/usr/lib with slibdir=
/lib mandir=/usr/share/man infodir=/usr/share/info enable checking=release
enable languages=c,c++,ada,fortran,objc,obj c++,java host=i586 mandriva lin
ux gnu with cpu=generic with system zlib enable threads=posix enable sha
red enable long long enable __cxa_atexit disable libunwind exceptions en
able clocale=gnu enable java awt=gtk with java home=/usr/lib/jvm/java 1.4.2
gcj 1.4.2.0/jre enable gtk cairo disable libjava multilib enable ssp dis
able libssp
Modèle de thread: posix
version gcc 4.2.2 20070909 (prerelease) (4.2.2 0.RC.1mdv2008.0)
Thanks you for your answer
01-02-2009 10:14 AM
Please see the already started discussion on the NI forums.
