07-13-2018 01:25 PM - edited 07-16-2018 09:29 AM
Hello Linux group. I am working through a problem and wanted to see if anyone has seen it before, and leave breadcrumbs/documentation if I do solve it.
I am trying to take a VERY BASIC subvi, hello world.vi (above) and create a Shared Library (.so file) from it. I am working on OpenSUSE and LabVIEW 2018.
However I get the following Error when building the .so:
Error 1 occurred at System Exec: /usr/lib64/gcc/x86_64-suse-linux/8/../../../../x86_64-suse-linux/bin/ld: cannot find -lstdc++ collect2: error: ld returned 1 exit status
At first I thought "oh no! GCC must not of installed libstdc++! but the following check on the Development environment returned:
zypper se libstdc++ Loading repository data... Reading installed packages... S | Name | Summary | Type ---+-----------------------------+-------------------------------------------------------+-------- | libstdc++-devel | The system GNU C++ development files | package | libstdc++-devel-32bit | The system GNU C++ 32bit development files | package i+ | libstdc++6 | The standard C++ shared library | package | libstdc++6-32bit | The standard C++ shared library | package | libstdc++6-devel-gcc7 | Include Files and Libraries mandatory for Development | package | libstdc++6-devel-gcc7-32bit | Include Files and Libraries mandatory for Development | package | libstdc++6-devel-gcc8 | Include Files and Libraries mandatory for Development | package | libstdc++6-devel-gcc8-32bit | Include Files and Libraries mandatory for Development | package | libstdc++6-gcc7 | The standard C++ shared library | package | libstdc++6-gcc7-32bit | The standard C++ shared library | package | libstdc++6-gcc7-locale | Standard C++ Library Locales | package | libstdc++6-locale | Standard C++ Library Locales | package
I wonder if this problem is similar to These Threads and I am currently investigating if any of those solutions work.
Also, this thread from 8 years ago suggests there is a specific build of libstdc++ needed for LabVIEW. Does anyone know which version(s) are acceptable for LabVIEW 2018?
**Edit**
I was originally working off of this knowledge base article.
When a similar error has been present on other environments, the solution has been to create a Symantec link to the x86 libstdc package. However it is difficult to understand where LabVIEW is expecting this package to 'be' in the first place.
07-16-2018 10:25 AM
Update: I am building the 'officially suggested' SuSE distro now and re-testing. This could be the problem.
07-17-2018 11:21 AM
Update, problem persists. I attempted the same on a LabVIEW openSuSE 42.2 machine. Has anyone seen anything like this before? has anyone been able to get .so builds working on a different Distro/version?
process as follows:
[0] Install GCC
sudo zypper in gcc
[1] Install LabVIEW 2018 Linux Full from ISO
./INSTALL
[2] Confirm the Development Engine is running by creating a project with a helloworld.vi
[3] Install LabVIEW 2018 Application Builder
[4] Restart for good measure
[5] Try to make a shared object from hellworld.vi:
Error Log:
07/17/18 12:05:29 PM [General] Project: /home/nick/Documents/LabVIEW_Projects/Hello_World/Hello_World.lvproj Target: My Computer Build Specification: My Shared Library OS: Linux x64 4.4.104-18.44-default [Source Files] /home/nick/Documents/LabVIEW_Projects/Hello_World/main.vi Mon 16 Jul 2018 05:44:23 PM EDT 1 [ERROR] Code:1 System Exec: /usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld: cannot find -lstdc++ collect2: error: ld returned 1 exit status [Output Files] [Errors] Click the link below to visit the Application Builder support page. Use the following information as a reference: Error 1 occurred at System Exec: /usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld: cannot find -lstdc++ collect2: error: ld returned 1 exit status Possible reason(s): LabVIEW: (Hex 0x1) An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @. 07/17/18 12:05:30 PM
07-18-2018 09:43 AM
Update: Workaround but not 'really' a solution:
'Build Shared Libraries' option works out of the box on CentOS-7
I will fix the missing dependencies on SuSE and post what-I-did later, but right now I need to get back on schedule.
When you think you are 90% done with a project you are 50% done.
07-19-2018 08:39 AM
@szewczak/usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld: cannot find -lstdc++ collect2: error: ld returned 1 exit status
Sad, that we don't see the actual gcc/ld command. They must be calling it in a pretty weird way (perhaps overriding system library patches), otherwise the linker would find it.
Maybe try tracing it (strace) and check how the toolchain is called exactly.
01-29-2019 04:49 AM - edited 01-29-2019 04:58 AM
As I run exactly in the same error on a fresh CentOS 7.6 installation, I tried to strace labview while it was creating the shared library.
Error 1 occurred at System Exec: /usr/bin/ld: cannot find -lstdc++
I am attaching the txt file output of the strace command.
I am quite new in Linux and I am not able to extract any useful info from the file.
The only section that seems interesting is the following...
11:52:20 stat("/usr/local/natinst/LabVIEW-2018-64/AppLibs/liblvrtdark.so", {st_mode=S_IFREG|0777, st_size=11281176, ...}) = 0
11:52:20 pipe([19, 20]) = 0
11:52:20 pipe([21, 22]) = 0
11:52:20 pipe([23, 24]) = 0
11:52:20 clone(child_stack=0, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7fecb09b0a50) = 19627
11:52:20 close(19) = 0
11:52:20 close(22) = 0
11:52:20 close(24) = 0
11:52:20 write(20, "", 0) = 0
11:52:20 close(20) = 0
11:52:20 select(1024, [21 23], [], NULL, NULL) = 1 (in [23])
11:52:20 --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=19627, si_uid=1000, si_status=1, si_utime=0, si_stime=4} ---
11:52:20 read(23, "/usr/bin/ld: cannot find -lstdc+"..., 8192) = 77
11:52:20 select(1024, [21 23], [], NULL, NULL) = 2 (in [21 23])
Does it mean that the -lstdc++ should be located in ...LabVIEW-2018-64/AppLibs/..
Might be silly, but I don't know what to guess.
Any help/hint?
08-31-2022 07:42 AM
