10-07-2016 07:19 AM
Using CentOS 7:
[root@measure NI4882_Linux_3_2_0]# uname -r
3.10.0-327.36.1.el7.x86_64
NI-488.2 version 3.2.0f0
is about to be installed using rpm at /usr/local/natinst
Would you like to continue? [Yn] y
Installing NI-488.2 version 3.2.0f0...
Pre Installation .
Post Installation .
Pre Installation .................
Preparing... ################################# [100%]
Updating / installing...
1:labview-2012-rte-12.0.1-6 ################################# [ 8%]
2:nipalerri-3.0.0-f0 ################################# [ 17%]
3:nimdnsresponder-2.2.0-f0 ################################# [ 25%]
4:nikali-2.5.1-f0 ################################# [ 33%]
5:nipalki-3.0.0-f0 ################################# [ 42%]
6:nipali-3.0.0-f0 ################################# [ 50%]
7:ni4882ki-3.2.0-f0 ################################# [ 58%]
8:nispyi-2.8.1-f0 ################################# [ 67%]
9:niiotracei-3.1.0-f0 ################################# [ 75%]
10:ni4882i-3.2.0-f0 ################################# [ 83%]
11:ni4882i-3.2.0-f0 ################################# [ 92%]
12:nipali-3.0.0-f0 ################################# [100%]
Post Installation .
Warning: nikali post installation failed! /tmp/nikaliPostInstall.log follows:
Configuring for linux kernel version 3.10.0-327.36.1.el7.x86_64.
********************************* NOTE *********************************
Using kernel headers found in /lib/modules/3.10.0-327.36.1.el7.x86_64/source.
If this does not correspond to the location of the 3.10.0-327.36.1.el7.x86_64 headers,
then define KERNELHEADERS in your environment to point to the location
of the kernel headers, define KERNELTARGET as the version of the
kernel for which to compile, and then rerun ./configure.
Kernel has version.h in include/generated/uapi/: yes
Kernel has reparent_to_init(): no
Number of arguments for do_munmap(): 3
Kernel has vm_mmap(): yes
Kernel has vm_munmap(): yes
Kernel has VM_RESERVED: no
Kernel struct pci_dev has busn_res member: yes
pte_offset function: pte_offset_kernel()
Levels in page table: 4
Kernel has remap_pfn_range: yes
Kernel has kzalloc: yes
Kernel has chained SGL support: yes
USB altsetting name: cur_altsetting
Kernel has usb_get_intf(): yes
Kernel has intf_cache member in usb_host_config: yes
Kernel has ep[] members in usb_device: yes
Kernel exports usb_set_configuration(): no
Units of USB_CTRL_GET_TIMEOUT: msec
Kernel has owner member in usb_driver: no
Kernel has put_page_testzero(): yes
Kernel has mutex method: yes
Kernel has wait_for_completion_interruptible: yes
Kernel has config.h: no
Kernel has ioctl32.h: no
IRQ handlers have pt_regs: no
Kernel has work_struct and delayed_work: yes
Kernel supports fault method in vm_operations_struct: yes
Kernel has ioremap_wc: yes
Kernel has pgprot_writecombine: yes
Kernel has cred.h: yes
Kernel has UMH constants: yes
Kernel has create_proc_read_entry: no
Kernel has namespaced generic netlink API: yes
Kernel has genlmsg_new: yes
Kernel has family genlmsg_put: yes
Kernel has usleep_range(): yes
Kernel has RS-485 serial_core support: no
Kernel uses tty_port instead of tty_struct for tty helper functions: yes
Storing configuration in Makefile.in
If the values stored are incorrect they can be changed before running make.
Installing NI-KAL:
NI-KAL update failed.
CC
/usr/local/natinst/nikal/src/nikal/nikal.c: In function ‘nNIKAL100_initDriver’:
/usr/local/natinst/nikal/src/nikal/nikal.c:2028:4: error: implicit declaration of function ‘genl_register_ops’ [-Werror=implicit-function-declaration]
if ((status = genl_register_ops(&nikal_netlink_family, &nikal_netlink_ops))) return status;
cc1: some warnings being treated as errors
make[2]: *** [/usr/local/natinst/nikal/src/nikal/nikal.o] Error 1
make[1]: *** [_module_/usr/local/natinst/nikal/src/nikal] Error 2
make: *** [all] Error 2
ERROR: make of nikal kernel module failed, not installing kernel module.
updateNIDrivers should be called again after fixing the problem.
Logging failure...
Include the file /tmp/niSystemReport.out.gz when contacting
National Instruments for support.
Updating modversions database to include newly installed drivers...
FOR PATENTS COVERING NATIONAL INSTRUMENTS PRODUCTS, REFER TO
THE PATENTS.txt FILE ON /run/media/labmeasure/NI4882_Linux_3_2_0 AND/OR
www.ni.com/patents
* A reboot is required before attempting to use the
* NI-488.2 software.
Would you like to reboot now? [yes|no] ^C
Installer is aborted.
Any ideas?
Thanks.
04-04-2017 05:36 PM
This function is gone aeons ago. That's the price to pay with OOT kernel modules, that aren't properly maintained. Note: oot-modules are just a workaround for exotic usecases (usually just for kernel hackers). Production drivers should be patched directly into / maintained inside the kernel tree. The kernel's internals heavily change over time - there never have been any fixed APIs (not even to speak of ABI), and most likely never be. Even worse w/ proprietary blobs - that's just Russian Roulette. Maybe usable for some childs toy that's going to be thrown away after a year anyways, but absolutely not for industrial devices w/ longer lifetimes.
CC /usr/local/natinst/nikal/src/nikal/nikal.o
