Linux Users
Error compiling NI-KAL 17.0 with 4.14 kernel
My problem is similar to the one described here: https://forums.ni.com/t5/Linux-Users/Errors-compiling-NI-KAL-2-5-with-3-19-0-25-kernel/gpm-p/3420171
When executing "updateNIDrivers", I get the error:
error: initialization from incompatible pointer type
...plus many additional c++ errors
The only difference between the previous post and now is that I am trying to install the NI-KAL 17.0 driver on a newer kernel (4.14) on a Redhat-based distribution (Fedora)
The initial installation worked without a problem, it is only an issue when doing "updateNIDrivers"
Is the only solution to downgrade to a less recent kernel?
(3,164 Views)
We're seeing the same problem. It appears that the kernel's Generic Netlink communications interface has changed from the 3 series to the 4 series.
At minimum the GENL_ID_GENERATE define and genl_register_family_with_ops() function are missing from the 4.14 series kernel we're using
In the stock centos 3.10 kernel there exist the following that prevent the errors when building on 4.14
/usr/src/kernels/3.10.0-514.26.2.el7.x86_64/include/uapi/linux/genetlink.h:#define GENL_ID_GENERATE 0
/usr/src/kernels/3.10.0-514.26.2.el7.x86_64/include/net/genetlink.h:#define genl_register_family_with_ops_groups(family, ops, grps)
Perhaps someone from NI could reply and let us know if they plan to tweak their code to support the new netlink interface.
(3,107 Views)
Which overall driver are you trying to work with, and what version of that driver are you installing?
NI-KAL is installed with many of our drivers, included NI VISA.
(3,090 Views)
NI-KAL is installed with many of our drivers, including NI VISA and DAQmx. Are you on the most recent version of VISA/DAQmx/etc?
(3,086 Views)
@pkorsnick
Yes, that had been removed long ago.
Note that kernel *internal* APIs are always changing. OOT modules always need a lot of maintenance works (this is just intended as temporary workaround until landing in mainline).
Can't be repeated often enough: proprietary drivers are just a *REALLY* bad idea.
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
(3,047 Views)
