10-23-2017 04:02 PM
I've only ever used National Instruments products through the DAQmx Base drivers via C programs so I'm not sure what capabilities I may or may not have on Linux.
I saw today that DAQmx 7.4 and later supports "Simulated Devices" that allow one to make calls into the NI driver without having those devices physically present.
http://www.ni.com/tutorial/3698/en/#toc2
I'd love something like this in order to benchmark my Linux code on a variety of platforms- is it possible to use Simulated Devices on Linux?
10-23-2017 08:43 PM
I hope you're aware that only a few specific distros - in pretty old versions - are supported. Proprietary drivers just don't work reliably on GNU/Linux.
10-23-2017 10:27 PM
Hi metux,
I'm not sure what you're suggesting. Is there another C API other than DAQmx Base?
For what it's worth, I've never had serious problems with the DAQmx Base driver other than critically bad documentation.
10-24-2017 12:57 AM
The right solution would be writing proper IIO drivers. But as long as NI is keeping the necessary specs a state secret, it will require a lot of reverse engineering work.
Just buying hw from a more professional vendor like is much cheaper.
I've once evaluated the crios for some clients. Conclusion: unusable for us.
Maybe you're fine w/ some specific, old, unsupported distro and kernel.
Maybe you're fine w/ a broken cpu architecture called x86.
Maybe you're fine w/ a ugly proprietary API, instead of IIO.
--mtx
