Linux Users
2019 NI Drivers on ubuntu.
Cool, let me know how it goes
Message 11 of 29
(4,366 Views)
So, tried running visa today and its not working again.  Not sure what has changed, but when i try to run visaconf i get the error libnipalu.so failed to initialize, verify that nipalk.ko is build and loaded.  nipalk.ko is built, and is located at /lib/modules/5.0.0-32-generic/kernel/extra/natinst  .  lsmod does not show it running, but i am able to load it with modprobe.  However, even after loading i still get the error.  Any ideas?
thanks!
Message 12 of 29
(4,281 Views)
thanks!
It sounds like the nipal init script did not run.  Try unloading the nipalk kernel module (modprobe -r nipalk) and start the init script manually (/etc/init.d/nipal start).
Message 13 of 29
(4,266 Views)
Hmm... there is no nipal inside of /etc/init.d
Message 14 of 29
(4,236 Views)
That would certainly explain why it didn't run.  😉  It sounds like something went wrong with the install.
Message 15 of 29
(4,232 Views)
Any idea which rpm installs nipal? I assumed it was ni-pal but i don't get any errors when installing.
Message 16 of 29
(4,230 Views)
ni-pal-support
Message 17 of 29
(4,226 Views)
That was installed without any errors as well... At a loss,this used to work.
Message 18 of 29
(4,223 Views)
Okay, i have it running again.
All i had to do was get the scripts that should have been installed in init.d
I ended up copying them from a Centos8 machine i have set up.  I can provide them if anyone else needs them?
Message 19 of 29
(4,212 Views)
I am seeing the same error.  I could use those files.  It looks like I need to get a machine to do a CentOS install for just this type of scenario.
At the end of the my .deb install, I got the following.  I'm not sure if that has anything to do with it.
Errors were encountered while processing:
libnidrumc1-bin
ni-488.2-gpibenumsvc
ni-daqmx-ef
ni-pal-support
ni-roco
ni-visa-lxi-discovery
Message 20 of 29
(4,157 Views)
