08-09-2019 10:32 AM
Cool, let me know how it goes
11-07-2019 12:47 PM
So, tried running visa today and its not working again. Not sure what has changed, but when i try to run visaconf i get the error libnipalu.so failed to initialize, verify that nipalk.ko is build and loaded. nipalk.ko is built, and is located at /lib/modules/5.0.0-32-generic/kernel/extra/natinst . lsmod does not show it running, but i am able to load it with modprobe. However, even after loading i still get the error. Any ideas?
thanks!
11-08-2019 10:15 AM
thanks!
It sounds like the nipal init script did not run. Try unloading the nipalk kernel module (modprobe -r nipalk) and start the init script manually (/etc/init.d/nipal start).
11-12-2019 08:16 AM
Hmm... there is no nipal inside of /etc/init.d
11-12-2019 09:07 AM
That would certainly explain why it didn't run. 😉 It sounds like something went wrong with the install.
11-12-2019 10:49 AM
Any idea which rpm installs nipal? I assumed it was ni-pal but i don't get any errors when installing.
11-12-2019 11:10 AM
ni-pal-support
11-12-2019 12:41 PM
That was installed without any errors as well... At a loss,this used to work.
11-13-2019 09:48 AM
Okay, i have it running again.
All i had to do was get the scripts that should have been installed in init.d
I ended up copying them from a Centos8 machine i have set up. I can provide them if anyone else needs them?
12-31-2019 03:38 PM
I am seeing the same error. I could use those files. It looks like I need to get a machine to do a CentOS install for just this type of scenario.
At the end of the my .deb install, I got the following. I'm not sure if that has anything to do with it.
Errors were encountered while processing:
libnidrumc1-bin
ni-488.2-gpibenumsvc
ni-daqmx-ef
ni-pal-support
ni-roco
ni-visa-lxi-discovery
