Life Science
simulate ecg signal
On the Express VI connector pane you have access to all the controls you need for doing this. You may for example create an array with 10 different beat frequencies. Then you can generate a randomized mumber between 0 and 9 and use this to index the beat array. Due to your behavior in this forum I must insist on seeing some code before I can give more help. This forum will always give help to people that put in some effort. But you will never receive a turn key ready application
Message Edited by Coq rouge on 06-25-2009 09:38 AM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 13
(7,770 Views)
how if i want to make it automaticly randomize signal not by choosing the array between 1-9?
Message 12 of 13
(7,759 Views)
how about make it all automaticly?
Message 13 of 13
(7,745 Views)
