11-01-2011 07:05 AM
I would like to use USB NI-6008 with LabWindows CVI version 5.0. The hardware comes with DAQmx version 9.3.5, which does not support CVI v.5.0.
Any ideas how to use this CVI version with USB NI-6008?
Many thanks..
11-02-2011
12:11 PM
- last edited on
07-21-2026
02:24 PM
by
Content Cleaner
Hi there,
Like you said, DAQmx is only officially compatible with LabWindows/CVI 7.0 or later. This link has more information on this compatibility: https://www.ni.com/en/support/documentation/supplemental/06/using-ni-daqmx-in-labwindows-cvi.html
In addition, USB-6008 is only officially compatible with DAQmx (previously, the plaform was Traditional DAQ). You would need Traditional DAQ to work with CVI 5.0, but the USB-6008 doesn't officially work with that.
Someone here might have an alternative solution, but though it seems you need to use CVI 5.0, is it possible to upgrade this?
11-07-2011 01:23 AM
Thanks Ravi.
I upgraded CVI and all is good again..
Cheers.
Martin
