I wrote a program similar to this in Visual Basic using IMAQ Vision software and datasocket. My URL for the datasocket connection was dstp://localhost/image. I found the program worked the best when the reader and writer were in autoupdate mode. The real keys to simplifiying the code were the IMAQ Vision "Image to Array" and "Array to Image" functions. This allowed me to convert the image to a 2D array for transfer through datasocket.
Note, for an image approximately 300 x 300 pixels, the transfer time just over the local machine (Dell Pentium III with 128 megs of ram) was approximately 5 seconds.
Unfortunately, Datasocket cannot be used to send binary files. If this was an ASCII text file, you could use a URL of the form file://...
If you wo
uld like more information on the IMAQ Vision software, go
here. This is an ActiveX component, so you could easily build a project similar to the attached Visual Basic example in CVI.
regards,
Eric Meyer
