LabWindows/CVI
share external variables between DLLs files
I need to know if i can use the declaration "External int x" to share the variable x between many DLLs files or i need to use an other method
Thansk
(3,159 Views)
I recommend Get and Set functions. But if you really want variables, see here: MSDN.
For the Section use:     #pragma comment(linker, "/SECTION:.myseg,RW")
/* Nothing past this point should fail if the code is working as intended */
(3,088 Views)
