LabWindows/CVI
send ctrl-x in serial port?
Can someone help ,
How do i send "ctrl-x" in serial com port?
For example,
ComWrt ( 1 , "\n" ,  StringLength("\n") );
(8,194 Views)
Ctrl-X, or Cancel command, is ASCII character 24. You can format a string with this character and send the string:
sprintf (string, "%c", 24); ComWrt (port, string, 1);
You should be able to embed it directly into a string or send directlt to the port using "\030" (octal code of Ctrl-X):
ComWrt (port, "\030", 1);
(8,180 Views)
In addition to Robert's response, CTRL+A, CTRL+B, CTRL+C....CTRL+Z are all known as control characters. Every control character has the decimal value equal to the control letter's order in the alphabet, starting with A=1. For a more comlete list of Control Characters, check out the following table found on the wikipeia site:
Control Characters in US-ASCII
Logan S.
(8,175 Views)
Thanks for the all the help.
Im very happy now.
(8,171 Views)
