LabWindows/CVI
savepanelstate general protection fault
I'm once in a while receiving a "General Protection Fault" when using SavePanelState in CVI 2010 running Windows XP.
This a program that runs 24/7, and that function call is probably executed 20k times a day, and runs on number of benches with the same configuration and no problems.
It sounds similiar to the problem that was found a while back for 64 bit applications, the CVI Runtime engine is 10.0.1.419.
Any updates that would correct this available?  Any other ideas?
Terry
(3,146 Views)
Hi Terry,
There was a bug in 64-bit for SavePanelState, but it was related to the creation of the save file. It could only occur for 64-bit applications and SavePanelState would always fail. So I don't think that is related to your issue.
Am I correct that this issue only occurs on 1 system? How often does it occur?
Are you able to reproduce this with the debugger attached? Is there an address attached to the fault?
Could you generate a crash dump and send it to us?
How To Create and Submit a Crash Dump to NI
(3,138 Views)
My program has run error free since commenting out that line of code.
When it crashed the system reported a general protection fault at 0x686358c4.
I need the bench to run right now, so it will be a while before I can try to get a "Crash Dump", but thanks for the information.
Terry
(3,115 Views)
