LabWindows/CVI
right click popup menu included "copy, paste"
Dear:
      There are about sixty test string control In my application panel, and I want to make a right click popup menu include such functions as "copy, paste,cut". Should I generate sixty callback functions by EVENT_RIGHT_CLICK to complete this requirement?
      Is There any other convenient methods to add such standard windows function popup menus?
      Thanks very much!
(3,338 Views)
Here you can find an example that shows how to implement Context Menus for Controls:
You can use the same callback for all of your controls, and use the "control" parameter of the callback, to identify the active control.
Hope this helps!
(3,325 Views)
